Where to buy oil temp sender?
Postby Twolitre » Thu Dec 09, 2010 12:07 am
I need a replacement oil temp sender that goes in the sump plug as my factory mitsi one is leaking :roll: and I don't want to pay dealer prices although I haven't actually priced one up yet. but I can't imagine it being cheap.
Twolitre
Postby neo » Thu Dec 09, 2010 9:57 am
repco'z will have the tridon catalog. if you can take the sender / get the thread + pitch they can work out which generic one to use **
** assuming you dont get a muppet
neo
Postby EssDub » Thu Dec 09, 2010 9:59 am
Sorry to hijack, but on a similar note...
Is it possible to by the adaptor thread for one of those sandwich plates for these temp/pressure senders? Im talking about the part that fits in the plate and screws directly onto the thread on the block :)
1992 SW20 MR2 GT-S Turbo
Previous Rides: Mazda 323, Toyota Levin BZ-G, 1992 SW20 MR2, 1994 Gen3 SW20 MR2 T-Bar
EssDub
Postby Twolitre » Thu Dec 09, 2010 11:39 am
neo wrote:repco'z will have the tridon catalog. if you can take the sender / get the thread + pitch they can work out which generic one to use **
Just had a look on Tridon's website and am assuming you are referring to using a water temperature sender for my application as in the link below?
http://www.tridon.com.au/Products/Product.aspx?SG=8&S=35&G=483&P=2012
Twolitre
Postby matt dunn » Thu Dec 09, 2010 10:12 pm
All the oil temp senders I have seen are different to water temp,
as oil temp usually is hotter than water temp,
so the resistance to temperature relationship is different.
