How do you adjust an HKS SSQV?
Postby Lockie » Wed Dec 22, 2010 6:38 pm
Just wondering how do people adjust the HKS SSQV's from either soft or hard?
Cheers.
Lockie
Postby iOnic » Wed Dec 22, 2010 7:10 pm
Loosen 6mm (from memory) nut on the back. Turn bolt clockwise to tighten or anti clockwise to loosen. Tighten 6mm nut on back.
Postby sergei » Thu Dec 23, 2010 8:38 am
I pulled apart a Chinese copy of this BOV, and that screw only adjusts how much diaphragm is opening (basically is a stopper), and not the spring....
Postby iOnic » Thu Dec 23, 2010 6:34 pm
The adjustment bolt pushes on a metal cap attached to the spring. That adjusts how much travel the diaphragm has but also preloads (compresses) the spring which changes how much pressure differential is needed to open the valve. With the bolt all the way out these horrible BOV's make the world's most god awful noise with very little boost. With the bolt all the way in you need a fair bit of boost to open them and hear the noise of your ears being raped.
Postby Lockie » Thu Dec 23, 2010 10:46 pm
"God awful noise" being that flutter noise by any chance?
Lockie
Postby iOnic » Fri Dec 24, 2010 8:24 am
That and the high pitched ear piercing noise :lol: It's all down to personal preference though. Some people like that sound. Others....not so much.
Postby Lockie » Fri Dec 24, 2010 11:19 am
Yeah, I figured that's what you mean't :D
It also depends on how much psi you're currently running as well correct? I mean the higher the psi, the more pressure in the system? Which would then make it louder I guess.
If that's the case, the Mazda GTR's only set on it's stock 7psi at the moment :?
Lockie
Postby sergei » Fri Dec 24, 2010 12:18 pm
iOnic wrote:That and the high pitched ear piercing noise :lol: It's all down to personal preference though. Some people like that sound. Others....not so much.
You can fix high pitch whistle by removing plastic Mercedes logo round thingy from that BOV.
Postby Lockie » Fri Dec 24, 2010 7:35 pm
You mean the removeable fin
Lockie
Postby sergei » Fri Dec 24, 2010 11:44 pm
Lockie wrote:You mean the removeable fin
yeah, centre thingy.
Postby Lockie » Sat Dec 25, 2010 12:09 pm
Um, what bolt is it that you can either losen off or tighten more?
The problem is that there's EIGHT of them around the centre fin, plus at the rear.
So which one is it...
Lockie
Postby loudstealthGT-Four » Sat Dec 25, 2010 12:32 pm
Lockie wrote:Um, what bolt is it that you can either losen off or tighten more?
done a quick google search and have read that there is no adjustment screw on the newer versions of the hks ssqv
What version do you have?
loudstealthGT-Four
Postby Lockie » Sat Dec 25, 2010 12:33 pm
Well that's gay.
It's the new one lol
Lockie
Postby iOnic » Sat Dec 25, 2010 1:03 pm
Big nut+bolt on the back. If yours is a new version - it won't have it and isn't adjustable. If it does, go for gold.
Postby Lockie » Sat Dec 25, 2010 1:07 pm
Nah, mines the new one.
Lockie
Postby TRD_ZERO » Sun Dec 26, 2010 3:58 pm
You cant just remove that merc badge fin looking thing as it also acts as a seal in the front, I tried with mine back in the day. There are replacement round inserts that you can buy if you dont want it squeaking away.
Previous:
TRD_ZERO
Postby Lockie » Mon Dec 27, 2010 11:45 am
Yeah, I've heard about being able to buy different inserts. Where abouts from do you know?
Lockie
Postby TRD_ZERO » Tue Dec 28, 2010 12:20 pm
Ebay
Previous:
TRD_ZERO
Postby Lockie » Wed Jan 05, 2011 12:15 pm
Cheers.
Does anyone know what type of blow off valves you can buy new that actually are still designed with the option of either a soft or hard postion?
I only know of the Greddy RS Trust ones.
Lockie
Postby loudstealthGT-Four » Wed Jan 05, 2011 5:54 pm
Ive got a GReddy Type S BOV which is adjustable between hard and soft
loudstealthGT-Four
