Stock 4age with 3sgte injectors????
Postby KIPH8N » Tue Dec 28, 2010 6:17 pm
I got some 3sgte injectors that i want to put on my standard 4age 20v. Will it harm the engine? Increase performance??
KIPH8N
Postby Bling » Tue Dec 28, 2010 6:20 pm
Why would you do that? :? I can only imagine bad results..
Postby KIPH8N » Tue Dec 28, 2010 6:22 pm
I thought the car would go harder because of more fuel in the engine. lol..
I just put it on but haven't started the car yet. Whats going to happen if i start it up.
KIPH8N
Postby loudstealthGT-Four » Tue Dec 28, 2010 6:22 pm
not sure on the compatibility of 3SGTE and 4AGE injectors.
Wont do anything in terms of performance
loudstealthGT-Four
Postby Bling » Tue Dec 28, 2010 6:23 pm
Well it's your car, but sounds like a silly idea to me.
No it won't go harder by just replacing the injectors, the factory ones actually provide enough fuel :wink:
Postby Dell'Orto » Tue Dec 28, 2010 6:27 pm
It'll run rich as hell, 20v's dont really need any help in that department
Postby KIPH8N » Tue Dec 28, 2010 6:57 pm
I just wanted more power but keeping the motor NA.
KIPH8N
Postby Bling » Tue Dec 28, 2010 7:16 pm
How big is the budget?
Postby KIPH8N » Tue Dec 28, 2010 7:17 pm
I can spend a grand. Its a silvertop 4age though.
KIPH8N
Postby celica_xr9145 » Tue Dec 28, 2010 7:23 pm
have you done the usual headers, intake and exhaust? Even a good service will get more power back.
www.Garage-X.org - Car Awesomeness
Facebook.com/garagexnz - Now on FB!!
95' Zenki Silvia S14, 99' BMW 328i E46
celica_xr9145
Postby KIPH8N » Tue Dec 28, 2010 7:29 pm
Which headers shall i use. Cant seem to get my hands on them. I got a pod filter, ngk irradium spark plugs. Still got the standard exhaust. Getting the car serviced tomorrow ( oil, oil filter and coolant ) Using castrol magnetic.
KIPH8N
Postby gasman » Tue Dec 28, 2010 7:52 pm
i reckon you will be pushing some hard power before you outflow the stock injectors on a 20v in NA form.
"What can possibly go wrong?"
gasman
Postby Bling » Tue Dec 28, 2010 8:00 pm
Pod filter will usually lose you power. You could source some blacktop extractors, but really to get good gains, you need pretty deep pockets.
Perhaps some nice lightweight mags 15s or something, and spend some $$ making it handle better.
Postby Dell'Orto » Tue Dec 28, 2010 8:06 pm
You'll probably need to get some out of Japan, I imported a set of HKS ones for my car. Only made 3kw gain in peak power, but made huge midrange gains. Though I imagine with a decent intake setup and exhaust, the gains would have been even more impressive (car is otherwise stock)
Postby MAC_HATER » Tue Dec 28, 2010 8:12 pm
bigger injectors but keeping N\A will make the car run rich as hell and make you lose power - so you get the bad fuel ecomomy and a shit running engine
although i have heard good stories from people using 3SGTE injectors on a 4A-GTE Conversion
if you want to keep it N\A then focus on flow - but then again a stock 4age pretty much has awesome flow - changing shit will more than likely cause you to lose power - or in the case of a friend who put "race" greddy extractors on his blacktop lost 20HP from 1000-6000rpm and then gained 3HP from 6000-8000rpm - the losses far outweighed the gains D:
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Postby KIPH8N » Tue Dec 28, 2010 8:12 pm
Its hard to find blacktop extractors. Yeah i would need alot of cash for that. Have people supercharged a 20v because i got a sc14 supercharger which i bought for my silvia. Or i could get a turbo setup and run like 6psi? Standard bottom end gze pistons and trd .8mm headgaskit?
KIPH8N
Postby AWShev » Wed Dec 29, 2010 6:12 pm
keep an eye out for ae101 4agze pistons and rebuild ur motor with those
then fit ur supercharger / turbo and injectors with aftermarket management
then get a good tune
i know ive exceded ur budget but u would end up with a reliable motor
u could run on 14psi all day
provided the tune is right
AWShev
Postby Al » Wed Dec 29, 2010 8:10 pm
Strip it out. Absolutely everything bar the drivers seat.
Replace the leads, plugs, rotor and dizzy cap, air filter, fuel filter with genuine parts (maybe not plugs, some cheap copper NGK's will be sweet).
Run some high 14 second 1/4's.
Al
Postby KIPH8N » Wed Dec 29, 2010 8:28 pm
AWShev wrote:keep an eye out for ae101 4agze pistons and rebuild ur motor with those
what ecu shall i use? i got a silvertop engine which has ran a main bearing could i use that? how much would be a crank ground?
KIPH8N
Al wrote:Strip it out. Absolutely everything bar the drivers seat.
really? isnt 14second a bit too fast for a standard silvertop motor?
KIPH8N
