suspension walk
suspension walk
Postby tsoob » Mon Dec 27, 2010 7:09 pm
I cant seem to work this out with my car:
It has a heavy duty sway bar and lowered springs, for some reason it has a horrible 'walk' or left to right pull, it seems to be when you come on or off the boost but the car rocks sideways..
Im wondering if the shocks are now poked but wanted to run this past some of the guys on here.. Thoughts please boys :)
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby RedMist » Mon Dec 27, 2010 8:46 pm
Shocks would have been my pick as well.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby siren676 » Mon Dec 27, 2010 10:13 pm
torque steer?
siren676
Postby matt dunn » Mon Dec 27, 2010 10:47 pm
siren676 wrote:torque steer?
That would be my guess too.
Postby loose_unit » Mon Dec 27, 2010 10:57 pm
Whats the alignment like?
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby Bling » Mon Dec 27, 2010 11:26 pm
Engine mount f**ked which is causing the engine to sway too much?
Postby Lloyd » Tue Dec 28, 2010 8:56 am
Blown head gasket?
Postby DexGT » Tue Dec 28, 2010 9:17 am
If it goes one way when accelerating and the other way when braking it could be a worn drive flange in one of the front hubs . The back bearing wears on the flange and allows movement so the car toes in or out depending on accel or deccel , easiest way to check is remove the wheel undo the CV nut and try to pull the flange out by hand. I had 2 or 3 of these on the starlet before I figured out how to loctite the bearing races on :lol: .
Or it could be what the others have suggested , thou I think BHG is less likely :lol: 8O
DexGT
Postby Adamal » Tue Dec 28, 2010 9:28 am
Lloyd wrote:Blown head gasket?
Hahah!
When you feel it pull, where do you feel it first, like in the chassis or through the wheel?
Postby XSVWGN » Tue Dec 28, 2010 9:32 am
bahaha yea of course it is!! where is MAGN1T when you need to make that call haha.
My wagon does the same when im on boost... steers across the road. But im jjust putting it down to torque steer :P
Matt
2008 Kia rio - work car
XSVWGN
Postby pc » Tue Dec 28, 2010 11:12 am
If it steers across the road without pulling the steering wheel it won't be torque steer. I drove 4WD car briefly that did this, I assumed it was a diff fault.
Variable toe sounds possible too though, has everything suspension & steering related been checked for wear/play?
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby tsoob » Tue Dec 28, 2010 11:19 am
Torque steer... possible, but I have a very very tight lsd, it just hooks up and goes.. and this has just started happening lately, and its getting worse.
Shocks, my first thought, and i'm sure i have a spare pair at the shop so ill try those and see how it goes.
Wheel alignment is pretty good was done around 5k's ago, ill try a recheck once i have done the shocks.
I have rebuilt all the cv shafts, i do need to do the wheel bearings and will also do ball joints and tie rod ends, BUT i want to wait until i do the brake upgrade.
Where do these flanges you speak of go??
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Malcolm » Tue Dec 28, 2010 11:32 am
by drive flanges I think he means hubs
What are your bushes like? My AW11 used to steer under left under drive and right under overrun because the bushes would let the arms move around and change toe, easily fixed with a set of urethane bushes.
Postby tsoob » Tue Dec 28, 2010 12:03 pm
Malcolm wrote:by drive flanges I think he means hubs
Which bushes??
all my controll arms are nolethane
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Malcolm » Tue Dec 28, 2010 1:26 pm
I'm not at all familiar with a Corolla's suspension, but if all the bushes in your arms are urethane then that's unlikely to be the issue.
Postby Mr Revhead » Tue Dec 28, 2010 2:55 pm
Unless they weren't lubed correctly and they could be flogged out. Happens real fast.
Postby 85AW20v » Tue Dec 28, 2010 3:54 pm
And check the back end as well as the front. Flogged rear bushes could cause "realignment" under acceleration too.
See ya
Simon
85 MR2 20v
85AW20v
Postby DexGT » Tue Dec 28, 2010 10:46 pm
Drive flange is the thing that has the wheel studs in and the spline for the CV to go thru. It goes inside the wheel bearings in the hub.
DexGT
Postby loose_unit » Wed Dec 29, 2010 12:05 am
Mine did a similar thing not long ago, turned out to be the fact that i had a new tyre on one side and a half worn one on the other, caused a pretty big walk to one side under acceleration like you describe. Changed tyres around so it was even and it was instantly gone.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby Malcolm » Wed Dec 29, 2010 10:59 am
DexGT wrote:Drive flange is the thing that has the wheel studs in and the spline for the CV to go thru. It goes inside the wheel bearings in the hub.
The part you call a drive flange is more correctly known as a hub. The part you call a hub has about a billion different names, but upright or steering knuckle are some of the more common ones
