Battery positioning and mounting (sealed)
Postby MrOizo » Mon Jan 10, 2011 1:38 pm
Been looking at the sealed batteries and wondering if these can be mounted on their side. At this stage under the floor where there is a bit of room.
They are wet ones but sealed - are these to simply make these maintenance free?
It's really only to keep a second alternator happy when the batteries in the trailer aren't connected. Will something small-ish be fine here?
Also, anyone got a hook up? :)
Cheers.
MrOizo
Toyspeed Legend
Postby CAMB01 » Mon Jan 10, 2011 8:06 pm
Although the batteries are sealed they will still leak eventually if left on there side unfortunately, so can only be installed upright.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby MrOizo » Mon Jan 10, 2011 8:34 pm
Ok cheers. Won't take much to mount upright I guess.
MrOizo
Toyspeed Legend
Postby CAMB01 » Mon Jan 10, 2011 8:56 pm
Assuming you are meaning the maintenance free automotive batteries?
CAMB01
Postby KinLoud » Mon Jan 10, 2011 9:31 pm
Adrian might be also meaning batteries out of the jumper packs... are they gel or liquid? Do they care about orientation.
Ken
Postby Dell'Orto » Mon Jan 10, 2011 10:47 pm
Those gel batteries from jump packs etc (Think they're AGM actually) arent terribly concerned with their orientation
Postby MrOizo » Wed Jan 12, 2011 6:51 pm
Thanks Cam.
I wasnt talking about the starter pack ones as such but might as well include these. I was more interested in a 'sealed' battery tht can be found at the main retailers like Ripco and SuperCheap.
I will look into a AGM/Starter Pack based battery - putting on its side should save a bit of space and give good clearence.
Cheers.
MrOizo
Toyspeed Legend
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
