cozmoid wrote:Looks like some one peed in your fuel tank!![]()
If it has changed colour that significantly I would say it is very bad. Fuel only lasts around 6 months at best I think, even worse for av gas
cat007 wrote:cozmoid wrote:Looks like some one peed in your fuel tank!![]()
Yeah I think it's a bit naffed. Probably the main reason the supra won't start. Initially thought it was the injectors not getting power, fixed that. Then the fuel pump wasn't working when cranking, fixed that. Now hopefully this bad fuel is the last of the problems. Then I should be good to go for some launch control burnouts in the drive hehe
tsoob wrote:chuck a match in it and see
cat007 wrote:The rarity here would be the fuel is over a year old lol
sergei wrote:It pays to pull out the injectors and put couple of drops of acetone on the tips, if you think injectors don't fire because of gunked up fuel in them...
cat007 wrote:sergei wrote:It pays to pull out the injectors and put couple of drops of acetone on the tips, if you think injectors don't fire because of gunked up fuel in them...
Might have to pull them out. I can't get the car to run with fresh fuel and new plugs. It fires a couple of times after about 7-8 seconds of cranking, then nothing for another 5-10 seconds.
I did manage to get it to run for about 10-15 seconds, it was running pretty rough, but it idled, then as I tried to rev it a little, it coughed and spluttered and backfired with black smoke, then died.
I don't have any acetone, what else could I use to give the injectors a clean?
cat007 wrote:Sweet - will do that.
Soak just the tips or apply power to them and pure some through?
sergei wrote:cat007 wrote:So just soak the tips then? lol
yep.
You could also drip into the injector (rail end).
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
