fuel cut defender yay or neigh
Postby tim_blair » Fri Jan 14, 2011 1:22 am
standed 4age BT fuel cut seems to be around 4 psi
if i install a fuel cut defender and run 4 psi will i harm my engine
it currently runs nicely at 3 psi
this is currently a small step while i gather funds to get a new engine with gze rods and pistons and a link
girl: can I trust you?
me: you can trust anything :D
tim_blair
Postby sergei » Fri Jan 14, 2011 8:29 am
What fuel cut defender does is limiting voltage on the map sensor. Unless you have some form of extra injectors that take over, fuel cut defender will destroy your engine.
Don't bother and go straight for link. It will be cheaper in the long run.
Postby touge_ae101 » Fri Jan 14, 2011 10:09 am
don't even bother running any boost through a std blacktop with std rods. it will destroy it in a flash. blacktop rods can't even handle being used in a NA engine, yet alone any sort of boost.
i hope you aren't trying to use the std plenum as well??
touge_ae101
Postby tim_blair » Fri Jan 14, 2011 11:42 am
ive got gze rods and pistons just need to save to get them put in
my setup is mint i have made a good alloy plenum with trumpts etc
ok ill limit my boost so it doesnt fuel cut rather than get a defender
tim_blair
Postby tsoob » Fri Jan 14, 2011 9:23 pm
BBBAAANGGG
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby sark.inc » Mon Jan 17, 2011 10:40 pm
so can the factory ECU cope with a little boost?
sark.inc
Postby escortman » Tue Jan 18, 2011 7:14 am
nope it cant search theres so much 4agte info on here its not funny, or look through the project threads crap load there too
4x4 toyota blizzard offroader
escortman
Postby tsoob » Tue Jan 18, 2011 9:46 am
tsoob wrote:BBBAAANGGG
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby .:O4AGTZ:. » Tue Jan 18, 2011 11:16 am
All this brings into mind that quote: Do it once and do it right
.:O4AGTZ:.
Postby tsoob » Tue Jan 18, 2011 11:01 pm
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby levinguy » Wed Jan 19, 2011 12:18 am
do you care if your engine goes? if not, go hard and test the limits. but running boost on a stock blacktop block is asking for trouble, though i haven't done it myself. always wondered if it was the rods, or the rod bolts that let go in saying that.
when you say it runs fine at 3 psi, are you checking fueling etc?
there was a guy running 5-6 psi (if my memory is right), on a stock silvertop, turbo'ed with a link, when it was generally thought impossibile beforehand. so you never know...
levinguy
Postby matt dunn » Wed Jan 19, 2011 12:19 am
tim_blair wrote:ive got gze rods and pistons just need to save to get them put in
Cool, so by the time your ready to fit them
it will have tossed a rod and you will have to get a new block and crank to go with them..
Postby tsoob » Wed Jan 19, 2011 9:51 am
BBBAAANGGG
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby pc » Wed Jan 19, 2011 11:03 pm
...and head and valves... and if unlucky, when the pieces of piston\valve make it to the turbo...
BBBAAANGGG
as said, blacktops aren't strong enough in NA form.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby MAC_HATER » Wed Jan 19, 2011 11:23 pm
its no good saving up to put the good parts in and run boost on the engine anyway on its factory high rpm thin rods - they will quit and they will exit the block and then along with pistons and rods you get to replace the block and most likely the head as well
honestly dont push a stock blacktop with boost - it will push back and throw a rod based tanty and leave you with an even more expensive rebuild than planned 8O
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Postby shihad » Wed Jan 19, 2011 11:55 pm
pc wrote:as said, blacktops aren't strong enough in NA form.
are there cases of na blacktops throwing rods that haven't run bearings?
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby Bling » Thu Jan 20, 2011 12:18 am
Interested to know that too. I think half the problems would be running them low on oil and not using them for their intended use. They aren't race motors.
Postby Quirky » Thu Jan 20, 2011 2:55 am
can you even run 3 psi?
Ive seen minimum wastegates for maybe 5psi min.
Hello There
Quirky
Postby pc » Sat Jan 22, 2011 12:50 am
I've seen one 1st hand... and i've never seen a bluetop throw a rod, even with run bearings :D
red car
Manfield - 1:24s
pc
Postby pc » Sat Jan 22, 2011 12:54 am
BZG|Bling wrote:...not using them for their intended use. They aren't race motors.
Balls to that. If a factory engine in a factory configuration can't run at red line, then it's got a design flaw.
Different story if you get oil starvation from high cornering Gs though.
red car
Manfield - 1:24s
pc
