Flannelman wrote:Wishing to pump up the compression on a Silvertop.
Im aware of .8mm TRD gaskets and flat top pistons to give it a boost but how much can the head be plained before there comes complications in weakening the head?
Flannelman wrote:removing material from pistons would lower the compression ratio...
skimming the block would bump it up
CAMB01 wrote:Flannelman wrote:removing material from pistons would lower the compression ratio...
Not if you take material off the top to make the dish in the piston smaller.
All machining was done by me using a lathe and milling machine.
AceSniper wrote:CAMB01 wrote:Flannelman wrote:removing material from pistons would lower the compression ratio...
Still going to lower it, or you run longer rods to bring the pistons up higher?
