Engine Not Running On All 4 When Warm
Postby spoonza6 » Mon Feb 07, 2011 10:57 am
4efte engine
car from cold runs fine and smoothly on all 4 but as soon as its warmed up it starts to miss really really badly and sounding like a subaru
today im gonna have a go at the leads, and coil pack and spark plugs
have checked my wiring and it seems all good
could it be bad fuel? as it only happened after i filled up with GullForce 10 in rotorua but the car only started being an egg about Karaka/Papakura offramp
pretty perplexed at why it suddenly being like this
spoonza6
Postby iOnic » Mon Feb 07, 2011 11:28 am
Overheating coil pack possibly? Is it a factory setup? (ignition/ecu etc)
Postby spoonza6 » Mon Feb 07, 2011 11:40 am
VR4 Dual Coil Packs run by a G3
spoonza6
Postby AE82 FXGT » Mon Feb 07, 2011 12:24 pm
could be the force10, not sure if your supposed to use it in you car...
try getting it out or diluting it with normal petrol
AE82 FXGT
Postby Distrb » Mon Feb 07, 2011 12:46 pm
blown head gasket
Distrb
Regular Poster
Postby spoonza6 » Mon Feb 07, 2011 1:04 pm
Distrb wrote:blown head gasket
thats the one im fearing
spoonza6
Postby Distrb » Mon Feb 07, 2011 1:24 pm
then do leakdown test on the cylinder in question if going over the electrics doesnt bring any joy
Distrb
Regular Poster
Postby sik_gt_starly » Mon Feb 07, 2011 1:42 pm
had similar problem when id blown my headgasket on 4efte, didnt sound like a subaru but would run really rough/lack of power and almost seem like hitting fuel cut and backfire etc
Take off oil cap and or dipstick out and have a nosey if the oil is all milky.
doubt would be gulls force 10, used this alot on mine and ran fine
sik_gt_starly
Postby gepsk8 » Mon Feb 07, 2011 1:44 pm
check leads and plugs
O272754663
gepsk8
