4 wheel drive to rwd conversion
Postby LEAKER » Thu Mar 03, 2011 6:25 pm
So at this stage this is purely a theoretical thread but i'm thinking about rear wheel driving my celica. As far as i'm concerned this can be done the easy way or the harder/proper way.
Easy way: This i will be doing in anyway because it's easy, reversible and it will determine if i feel like keeping it rwd.
Basically unbolt the end housing on the transfer case, remove the old diff setup and replace with my spare set up which i will weld shut. Blank off cv outputs and machine down the old outter cv to bolt through the front hub to keep the wheel bearings tight. Easy to do, cheap and all that.
Hard way/Proper way:
Remove engine / Gearbox
Cut hole in fire wall and fabricate gearbox tunnel
Mount altezza 6 speed or W57 to 3sgte
Modify intake to accept north south engine setup
Custom exhaust manifold
Somehow (and this is the part i'm $&#$% on atm) re position the steering rack or source new steering rack etc (Advice, anyone?)
Modify driveshaft
Make new engine mounts
Make gearbox cross member
Drink 2 dozen beers and drown in sorrows when it turns to a mess.
Does anyone know what justins GT8 1uz twin turbo powered gt4 uses?
Cheers for any help or advice.
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Re: 4 wheel drive to rwd conversion
Postby levinguy » Thu Mar 03, 2011 8:18 pm
you don't even have to do that. just lock the center diff, put the cvs back in the hubs and gearbox without the axles, and be prepared to go thru a diff every week. seen it done twice. also seen it put back to 4wd twice.. go figure.
levinguy
Postby h8wrxs » Thu Mar 03, 2011 9:29 pm
why not just buy some ceffy or skyline, itll be cheaper and easier
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby 1I1 » Thu Mar 03, 2011 9:39 pm
Potential rear axle/diff issues trying to put all of power through rear end instead of spread over front wheels as well as?
TRD Clicky >>Here
1I1
Postby touge_ae101 » Thu Mar 03, 2011 9:42 pm
1I1 wrote:Potential rear axle/diff issues trying to put all of power through rear end instead of spread over front wheels as well as?
one has to assume it has power to put to the ground
lol i'm $&#$% maggot
touge_ae101
Postby GTTpower » Thu Mar 03, 2011 9:43 pm
Not to mention weight distribution all funny due to transverse engine/box layout.
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Steam/Origin ID: nzEP85
GTTpower
Postby Malcolm » Thu Mar 03, 2011 10:06 pm
If you search "rwd conversion", check the box to search for posts containing ALL terms, and only search in the tech forum, you'll get 2 pages of results, at least 4 of which relate to converting an ST185 to 4wd, such as this one:
viewtopic.php?t=38736&highlight=rwd+conversion
Most of them turn into a shitfight of "it's pointless/stupid/waste of time/way more work than you think" versus "don't listen to the haters, awesome idea, bro that's so original it'll be awesome I see no reason why it wouldn't be a good idea and I know because I've changed a couple of oil filters and installed a new headunit in my car" etc.
edit: I wanted to include this gem I just found in another thread:
Original Poster wrote:How Hard is A front skidda conversion to Rear Skidda?? Any Suggestions
RunningRich wrote:Well you sound like a complete idiot, so I'd have to say that (for you) the conversion would be very difficult indeed.
The easiest way for you to achieve what you want is to drive backwards...
:lol: gold
Postby Adamal » Thu Mar 03, 2011 10:32 pm
The easiest way to convert to RWD is to convert your car to money, and then convert that money into an MR2 or an Altezza or the likes.
Postby solitaire » Thu Mar 03, 2011 10:44 pm
Adamal wrote:The easiest way to convert to RWD is to convert your car to money, and then convert that money into an MR2 or an Altezza or the likes.
I am seriously considering getting out of the mr2 business...
My mr2 keeps magically turning money into, well nothing really
AE92, KZJ120, KDJ120
solitaire
Postby sergei » Thu Mar 03, 2011 10:47 pm
If you are after skids sell GT4 and buy Sylvia.
This way you don't get to molest a good car.
Besides why on earth you would downgrade your car?
"my car handles too well, better drink my own piss"
Postby Bling » Thu Mar 03, 2011 11:59 pm
sergei wrote:"my car handles too well, better drink my own piss"
Well played :lol:
Postby RS13 » Fri Mar 04, 2011 12:11 am
Well played :lol:
Yeah, got a lol from me as well, can't help but picture Bear saying it as well for extra lols..
RS13
Postby LEAKER » Fri Mar 04, 2011 8:18 pm
Man i don't care about weah weah buy a rear wheel drive to begin with. This isn't a thread asking for your opinion. I would like people that have done this sort of thing or have good experience to throw some ideas around on how to do it the proper way which eliminates all the problems with doing it the dodgy way. If you must know i want to do it because i like the idea of having a different car and being an engineering student it's good practice for me. I know that doing a dodgy rwd conversion is nothing new however doing a proper 3sgte north/south conversion on a st185 would be pretty cool and different in my opinion. So getting back on track i'm still a little stumped about how to get around the steering rack issue.
Cheers to those that can help.
LEAKER
Postby 1I1 » Fri Mar 04, 2011 8:22 pm
Re steering rack you could speak nicely to matt dunn on here and ask what they did in their AE101 when putting a 1JZ in it
TRD Clicky >>Here
1I1
Postby LEAKER » Fri Mar 04, 2011 8:25 pm
Malcolm just went through that thread and it's pretty much what i expected. The roll cage can be provided to accomodate for chassis flex as i expect that chassis twist would pose a huge issue.
LEAKER
Postby LEAKER » Fri Mar 04, 2011 8:27 pm
1I1 wrote:Re steering rack you could speak nicely to matt dunn on here and ask what they did in their AE101 when putting a 1JZ in it
Good call, ta.
LEAKER
Postby wde_bdy » Fri Mar 04, 2011 10:26 pm
For the rack, take a complete front crossmember from a RWD car and make it fit. Adapt as much of the front suspension as you can in order to match a factory setup in terms of geometry etc.
Callum
wde_bdy
Postby cedwards » Fri Mar 04, 2011 11:07 pm
viewtopic.php?t=73271
may be some ideas in here if you haven't read it yet
cedwards
Postby levinguy » Sat Mar 05, 2011 1:11 am
series 4 rx7 stuff may work depending on how you want to work it.
subura legacy 4wd early 90's steering racks may also suit if you can find hubs with the connectors low enough (a31 cefiros are close)
levinguy
Postby Sick Puppy » Tue Mar 08, 2011 9:17 pm
Can I suggest buying a parts GT4 with an unmunted chassis? There aren't many decent ST185 GT4's left, and if this goes to shit, there will be one less...
Project thread here
Discussion thread here
Sick Puppy
