4agze missing/no power :(
Postby KIPH8N » Sat Mar 05, 2011 10:08 pm
I bought a ae101 levin 4agze and its missing sometimes.
Sometimes when you start it up the revs drop and it turns off.
It doesn't have any power at all when you going uphill.
Cant fell the torque.
The person i bought it from said it might be a stuck valve.
What else could be the problem?
KIPH8N
Postby Dell'Orto » Sat Mar 05, 2011 10:15 pm
Checked the engine codes?
Postby AE92-5ONIC » Sat Mar 05, 2011 10:17 pm
MAP sensor
Timing
Spark
Do diagnosis, MAP sensor would be my best guess.
AE92-5ONIC
Postby KIPH8N » Sat Mar 05, 2011 10:18 pm
Dell'Orto wrote:Checked the engine codes?
whats an engine code?
KIPH8N
Postby KIPH8N » Sat Mar 05, 2011 10:20 pm
AE92-5ONIC wrote:MAP sensor
Timing
Spark
I could swap parts around from my silvertop like spark plugs and leads.
But how do i diagnosis the Map Sensor where is it located?
KIPH8N
Postby AE92-5ONIC » Sat Mar 05, 2011 10:21 pm
AE92-5ONIC
Postby KIPH8N » Sat Mar 05, 2011 10:32 pm
AE92-5ONIC wrote:http://www.troublecodes.net/Toyota/
looks quite confusing :(
KIPH8N
Postby nz_climber » Sat Mar 05, 2011 10:35 pm
in that case take it to a mechanic.
nz_climber
Postby KIPH8N » Sat Mar 05, 2011 10:36 pm
Reckon it could be a stuck valve?
He said its running rough in one cylinder.
KIPH8N
Postby Dell'Orto » Sat Mar 05, 2011 10:37 pm
nz_climber wrote:take it to a mechanic.
Next to impossible to diagnose over th net
Postby KIPH8N » Sat Mar 05, 2011 10:41 pm
I shall take it to a mechanic on Wednesday and update this post.
Just wanted to know if anyone had a problem like this with their car.
:D
KIPH8N
Postby 328FTW » Sun Mar 06, 2011 12:13 am
I had an issue like this. The centre of the electromagnetic pulley for the supercharger had come clean off, must have come loose.
But still mechanic is in order. If you can have it compression tested and right down what he says. Loads it could be, coil breaking down etc etc
328FTW
Postby TRD_ZERO » Sun Mar 06, 2011 10:41 am
Go in the enginebay look for a small black box that says diagnosis. Open it up. grab a paper clip or any sort of wire and jam one end in the terminal TE1 and the other end in E1 (there should be some sort of labeling as a reference). Now go and turn ignition on so that the lights come up on the dash eg.oil, brake, check engine light etc. Dont start the car.
follow the easy instructions below
Count number of flashes from CHECK ENGINE light.
If system is operating normally (with no detected faults), the CHECK ENGINE light will blink continuously
and evenly about 2 times a second.
Otherwise, the light will blink a number of times equal to the trouble code as follows:
The light blinks only (.5 second ON, .5 second OFF) when indicating a number.
The light will be OFF for 1.5 seconds between the first digit and the second digit of the code.
If more than one code is stored, the light will be OFF for 2.5 seconds before the next code is displayed.
Once all code(s) have been displayed, the light will be OFF for 4.5 seconds and then the whole sequence will repeat.
The diagnostic code series will continue to repeat as long as the check connecter terminals TEl and El are connected.
When finished, remove the jumper wire.
Its that easy.
You might have to do the count a few times to make sure you have the correct codes.
Get into it and start learning how to do some shit yourself.
Previous:
TRD_ZERO
Postby KIPH8N » Sun Mar 06, 2011 10:14 pm
328FTW wrote:I had an issue like this. The centre of the electromagnetic pulley for the supercharger had come clean off, must have come loose.
Some belt on the car makes a sqiky sound when accelerating i think its the supercharger belt. Could that be an issue?
KIPH8N
Postby KIPH8N » Sun Mar 06, 2011 10:15 pm
Its that easy.
Haha nice one man. Yes i shall do it tomorrow :D
Lets see what i get.
KIPH8N
Postby Adamal » Sun Mar 06, 2011 10:31 pm
KIPH8N wrote:Some belt on the car makes a sqiky sound when accelerating i think its the supercharger belt. Could that be an issue?
Well that sounds like the electromagnetic clutch is engaging, but the belt might need replacing. Check to see if its hard and cracked.
Postby KIPH8N » Sun Mar 06, 2011 10:35 pm
Yes the belt is hard. Where do i get a belt from? Does repco sell them?
KIPH8N
Postby Bling » Sun Mar 06, 2011 10:51 pm
I still think unless you can diagnose the fault yourself, take it to a mechanic. Sure you can replace the belt, but if that's not the problem.... then you're still at square one. Ask around for a trustworthy one and go from there.
Postby h8wrxs » Mon Mar 07, 2011 12:18 am
KIPH8N wrote: Does repco sell them?
those questions alone tell me youd be best to go to a mechanic who knows what they're doing
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby 328FTW » Mon Mar 07, 2011 3:59 am
If you take it in have them time the motor to 10*BTDC as well. Timing is a big factor so you will want that to spec. Sounds like it needs maintenance items like that doing.
328FTW
