In Car PC.......
In Car PC.......
Postby 3T-Rona » Tue Mar 08, 2011 12:46 pm
Any one into building In-Car pc's.......
ive seen a few installs about and it looks a rather cool idea, maybe a little nerdy but fuk it :)
Mostly would be used for the music side of things but also would have a direct plug in to my Link for trouble shooting an general flashness
Currently ive got no stereo, so i just run an amp powering my speakers, with a earphone type jack that goes to my phone cradle so i play music via that and have gps yelling at me through the speakers.....
anyone got suggestions/ideas.....
also looking at this sort of thing
http://www.trademe.co.nz/Browse/Listing ... =358486220
as it looks small enough to mount on the steering wheel or centre console.....
and is cheap as.....
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
Postby sergei » Tue Mar 08, 2011 2:12 pm
I built one myself.
about 3 years ago.
That was before Atom time, I used Via C7 mini-ITX mainboard, Pico-ATX automotive PSU and 4GB CF (with CF to SATA adapter).
The OS was kUbuntu 7.04, and I have quickly put together touch screen friendly front end for Amarok (via DCOP interface) in kommader (I am not a coder ;)).
The most expensive part was 7" touch screen.
Here are the issues I ran into:
Touchscreen is a lot less convenient than real hardware knobs and buttons.
Glare is the killer, you will require to script or wire the "illum" wire to dim at night.
While sound quality was OK, but nothing compared to real hardware like Alpine head decks. It took great deal of taking care of ground loops.
Need of a pointing device and keyboard for debugging (since I have built everything myself)
Even with mini-ITX you will find a bit of problem with space.
I compiled a custom kernel to make the thing hard boot in under 20 seconds.
Even if the PC sleeping it can drain your battery in few days, it needs to shutdown (or hibernate) after prolonged off times.
Because I used CF I could not hibernate (not enough disk space). This was before affordable SSDs (now 40Gb intel SSD is ~$145, then for that money all I could afford is 4Gb CF).
Particular motherboard I used had stability issues.
Eventually I scrapped it and got a real head unit. In hindsight, for $1500, I could have gotten an awesome headunit.
EDIT: add another $50 to the price of the pocket pc and you can buy a decent head unit with USB.
Postby Bling » Tue Mar 08, 2011 2:35 pm
Get a good headunit for sounds.
Get a cheap laptop for tuning.
Replace floorpan footwell sections with checker plate.
Easy 8)
Postby 3T-Rona » Tue Mar 08, 2011 3:11 pm
Easy 8)
had to be said didnt it..... :)
sweet cheers for ideas lads......
3T-Rona
Postby cogent » Tue Mar 08, 2011 4:09 pm
Hate to say it, but this might be one of the only situations where a mid range china android tablet might be a good idea.
Might.
cogent
Postby Alex B » Tue Mar 08, 2011 5:23 pm
Have a mate running a car pc with centrafuse, not cheap but bloody good. Let me know if you want more info and ill flick you his email address.
http://www.centrafuse.com/
Postby Elmo » Tue Mar 08, 2011 5:40 pm
I run a Netbook velcro'd to the dash, but hell, I am in a 4x4 with a large dash, mines mainly for mapping anyway
Elmo
Postby Simon K » Tue Mar 08, 2011 7:43 pm
My brother has one, PM "Canman" on NZ Hondas and he can fill you in(he builds them).
Simon K
TS Wannabe
Postby 3T-Rona » Wed Mar 09, 2011 7:33 am
Elmo wrote:I run a Netbook velcro'd to the dash, but hell, I am in a 4x4 with a large dash, mines mainly for mapping anyway
well its a 4wd so theres a start.... and i have a spare netbook.....
is it possible to somehow make a laptop boot with signal from the key.....
3T-Rona
Postby sergei » Wed Mar 09, 2011 8:13 am
yes it is possible, you hard-wire the power button the key via some logic circuit or micro-controller. There are some other ways of doing it (using USB for example).
Postby 3T-Rona » Wed Mar 09, 2011 10:18 am
sergei wrote:yes it is possible, you hard-wire the power button the key via some logic circuit or micro-controller. There are some other ways of doing it (using USB for example).
i spose its probably better if its manually booted really,
start- pc starts, drive to shop, turn off - pc turns off, start- pc starts, drive to beach, turn off- pc turns of...... on off on off.....
or am i worryin bout nothing?
3T-Rona
Postby sergei » Wed Mar 09, 2011 10:49 am
What you need is USB interface that has ability to wake up the PC and put it to sleep. I am not sure if such device exists on the market, but it is possible to build one using microcontroller.
With automotive PSUs they have logic - and depending how long ignition was on for they either initiate shutdown or sleep sequence or leave it on for another time period if in case you jump back in again and start the car.
Similar logic can be made with usb device (one way I can see is to pull apart USB keyboard with sleep button and trigger that with a micro).
EDIT: http://eegeek.net/content/view/40/32/1/0/
Postby Bling » Wed Mar 09, 2011 11:52 am
Do you need it going every time you use the car?
What are the power saving options available on it in relation to the screen being open / closed? Most laptops will let you specify what the pc does if the screen is closed, sleep etc.
What is the main use going to be of this? Seems like a lot of hassle just to get music, but I guess its for the fun of it mostly. Just thinking about the price of USB capable head units and comparing it to having to use a netbook. Amazing how much music you can fit on a usb stick 8)
Postby 3T-Rona » Wed Mar 09, 2011 12:03 pm
BZG|Bling wrote:Do you need it going every time you use the car?
mostly for the fun of it :D i already have the net book so theres one cost down.....
http://www.trademe.co.nz/Trade-Me-Motor ... 044707.htm
pre-made even......
3T-Rona
Postby gmacrae » Wed Mar 09, 2011 9:41 pm
get a secondhand netbook, pull screen off, hide it under seat or in dash, run display outta the vga port, most run on a 10v power supply, should be easy to get 10v down from the cars 12v without running some kinda goofy ac inverter just to convert back to dc. Most have 2 usb ports, run a USB hub if you need more, wireless USB kb/mouse will only take 1 or just use the netbook itself for kb/mouse. Could mount it so it comes out from glovebox on a sliding tray or something, with cable outs hidden on the sides. You could pull netbook apart to tap into power button so you can mount a button near the head unit
gmacrae
Postby 3T-Rona » Fri Mar 11, 2011 10:09 am
dwnloaded trial version of centrafuse......
cool but computer start times make it a lil gay.... may just have to get a stereo :D
3T-Rona
Postby Alex B » Fri Mar 11, 2011 11:04 am
Dont shut it down just hibernate it, will improve things a bit.
Postby gt4dude » Sun Mar 20, 2011 10:46 am
thought about it one day, this is what i would use
http://www.jaycar.co.nz/productView.asp?ID=XC4876
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby 3T-Rona » Mon Mar 21, 2011 7:44 am
gt4dude wrote:thought about it one day, this is what i would use
Yeh been through them and found a couple options even cheaper for laptop supply....
3T-Rona
Postby Barks » Wed Mar 30, 2011 1:01 am
There's a guy in Tauranga selling these: http://www.trademe.co.nz/Computers/Desktops/No-monitor/auction-364267252.htm
He can supply pretty much well anything you need to go with it too - SSD or SATA drives.
Bought a small form factor PC off him last week, good value.
"Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music"
Kristian Wilson, Nintendo, Inc, 1989
Latest rides: 2004 Avensis Wagon, GT Avalanche 1.0, GT Avalanche 0.5, Marin Toscana CX
Barks
