strx7 wrote:what was the water pump last done? does it always run with antifreeze/corrosion inhibitor? how long have you had the vehicle?
strx7 wrote:i'd be looking at the water pump
Santa'sBoostinSleigh wrote:
next step ali radiator? or maybe look at replacing the viscous fan?
Santa'sBoostinSleigh wrote:getting the radiator 'serviced' is most likely going to cost as much as a replacement one
i have read up on some aussie forums and its looking like the viscous fan is getting buggered and not cooling efficiently. unfortunately this is an expensive fix, but sounds like its problem solved when a new one is fitted
allencr wrote:Look at the tops of the core tubes, the 6-10 that are visible gives a good indication of all the others. If more then a few, 2-3, are clogged or have a heavy mineral buildup that'll restrict flow, then it needs cleaning.
The fan is useless & does nothing for engine cooling, except restrict airflow, at any speed over 25kph so that isn't your problem unless it's overheating when sitting still.
Is all the airflow going through the radiator, without any big gaps or panels removed that allow it to bypass the radiator?
matt dunn wrote:Santa'sBoostinSleigh wrote:getting the radiator 'serviced' is most likely going to cost as much as a replacement one
We have had one off a 1KZTE surf sent away and re-viscoused ??? lol
They pulled it apart and replaces the fluid or whatever in it.
When dead cold and you start the engine it should be noisy(fan blade noise) for a few seconds before they go quiet.
strx7 wrote:just drill a hole thru it and put a nail in it, direct drive fan.
