d2 coilovers - good or bad?
Postby Bling » Wed Mar 09, 2011 4:40 pm
No, I think its more of a case of be realistic with your expectations from what you buy. I mean how many sets will be running perfectly fine on the street, probably lots.
Spend 1k on a set of coilovers and expect 1k worth of quality.
Spend 5k and get 5k worth etc
Not sure much is designed to be driven over ripple strips and come off well :lol:
Postby h8wrxs » Wed Mar 09, 2011 4:44 pm
everyone i know who has had those purple d2's (5 people) have all had them leak or do similar things to those picture...
i dont know anything about the new black ones though
only reason im even lookin at d2's is theres a set on tardme for $450
think ill save my money for soemthing better then
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby Bling » Wed Mar 09, 2011 4:48 pm
Import something spendy 8)
Postby sik_gt_starly » Wed Mar 09, 2011 4:57 pm
cant really go wrong with a set of suspension for $450.
sik_gt_starly
Postby JustinSpiderholden » Wed Mar 09, 2011 5:03 pm
h8wrxs wrote:everyone i know who has had those purple d2's (5 people) have all had them leak or do similar things to those picture...
Save you coin for somthing decent in the long run you won't regret it
JustinSpiderholden
Postby Malcolm » Wed Mar 09, 2011 5:24 pm
sik_gt_starly wrote:cant really go wrong with a set of suspension for $450.
unless it's worse than what you already have.
Postby iOnic » Wed Mar 09, 2011 5:32 pm
Each to their own I guess. My D2's have been in the car for ~5-6 years now and I've never had a problem with them. In that time they've done a couple years of daily driving and weekend track days, attempts at drift days that more often than not resulted in my spinning out and going backwards over ripple strips or doing jumps in the infield - backwards. Even after sitting for 2 and a bit years there are no leaks and they're just as the day they were installed. If they broke tomorrow I think I'd still gladly say I got my money's worth out of them and they've fulfilled the job I wanted them to do and then some.
Every time someone asks about D2's those pictures of the S14 get thrown around and the general response is "D2's are crap because this guy broke a pair". Be realistic though, if you go driving on ripple strips you're bound to break something. D2's aren't the only sets of suspension that don't react to that kind of shock well. Ultimately, any coilover treated in that way will eventually fail - they're just not designed for it. Expensive suspension is not a substitute for showing care. Even the big brands bend if treated wrong.
Tein:
HKS:
For ~$1500 brand new I think D2's are good value for money. If you want entry level adjustable suspension, they'll do the job just fine. The spring rates they come with are usually overly stiff for street use but you can choose different spring rates at no extra charge when you buy them so just pick something sensible.
Postby shihad » Wed Mar 09, 2011 5:54 pm
bc's are same price just without the horror stories.
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby JustinSpiderholden » Wed Mar 09, 2011 5:59 pm
shihad wrote:bc's are same price just without the horror stories.
100% agree
Plus the damper adjusting on my D2s was crap, they didn't click or anything to give you any indication that you had changed the settings so it was very hard to set all 4 corners the same
JustinSpiderholden
Postby touge_ae101 » Wed Mar 09, 2011 6:11 pm
those TEINs looks pretty old school! of course anything is going to bend with a shaft that small. all the TEIN's i have seen (including mine) have a much much larger shock than any other type of coilover.
for $450 - yeah maybe if its better than nothing...
fir $1399 (as advertised) HELL NO!
BC's aren't that much more and neither are a near new set of TEIN or the like. could do a decent Koni setup with springs too which would be superior in performance.
touge_ae101
Postby 1I1 » Wed Mar 09, 2011 6:15 pm
You notice the ride difference when adjusting the dampers on BC's! I can't stand mine with anything other than fully soft (well maybe up to 7/30 possible clicks) in my Corolla. Tried them at around half way (which BC recommend for "sports driving") and they car was waaay to stiff / bumpy / sketchy doing 90km/h over a piece of road that can be done comfortably at a speed much much quicker than that.
TRD Clicky >>Here
1I1
Postby Emperor » Wed Mar 09, 2011 6:29 pm
iOnic wrote:
JustinSpiderholden wrote:Those were broken at Manfeild on ripple strips
Funny that. Turns out if you use a product in a situation it's not designed for, it's likely to fail. Who'd have thought. Manfeild's ripple strips are huge - not a pleasant experience being on them.
My Koni's have seen Pukes/Taupos/Manfields/Chch/Timarus rippled strips ALOT, and no damage in 5 years.
So for a set of D2's to do that seems to scream out crap to me.. I'd go BC over D2.
Emperor
Postby Akane » Wed Mar 09, 2011 6:44 pm
strx7 wrote:Curbs will bend anything.......
Not really, took out a curb side on so hard that the mag wheel had a chunk missing and the wheel bearing is knackered, the teins I have are still sweet (measured).
But then they do carry a $2.5k+ pricetag if brand new, compared to $1399 or whatever for D2.
Postby strx7 » Wed Mar 09, 2011 6:52 pm
In what vehicle? shocks in a double wishbone type set up get less punishment on impacts than mcphersons do.
Postby QikStarlie » Wed Mar 09, 2011 7:37 pm
JustinSpiderholden wrote:D2 suspension:
looks like this dude should have done up the top bolt properly
QikStarlie
Postby tsoob » Wed Mar 09, 2011 8:54 pm
the photos are of the gen 1 d2's
the gen2 stuff is a totally different product.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby h8wrxs » Wed Mar 09, 2011 8:55 pm
ive got bc golds in my evo and was really impressed with them for the money i paid
they are really hard when you wind them damper up but you definitely feel the difference when adjusted
h8wrxs
Postby pjay » Wed Mar 09, 2011 8:56 pm
Will rock D2's before I rock cutties.. LOLJK, I'll rock cutties while I save for D2's.
No srsly, as stated I'm a firm believer of you get what you pay for. If you're really serious about serious business, get the one with the bestest warrantee.
pjay
Postby Bazda » Wed Mar 09, 2011 9:39 pm
Either go for BC which is easily obtainable in NZ or ISC.
These are prob the only coilovers I would use that are made in Taiwan as I know their quality control is good and they have a very good customer base in the motorsport scene.
Postby Akane » Wed Mar 09, 2011 10:06 pm
MR2, rears, they're a mcpherson setup afaik.
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
