looking for 1mz-fe wiring or pinout diagrams - 1999
Postby chris77 » Sat Mar 05, 2011 12:34 pm
Have what we believe is a 1999 camry 1mz-fe engine to wire into an offroader . I am looking for a pin out or wiring diagram for it , found a couple but there are not correct , ie 1997 etc .
ECU no is 89666-06420 and engine no is 5329217 , is it possible to date this somewhere ? The ecu is a 4 plug and they are white .
Thanks
Chris
chris77
Postby strx7 » Sat Mar 05, 2011 7:22 pm
what posssed to you use a 1MZFE engine? even toyota dismantlers avoid them like the plague
Postby chris77 » Tue Mar 15, 2011 3:35 pm
So no one has any idea where I can find a diagram , bugger . Too risky buying one of the net as I do not know if it will be the right one .
Chris
chris77
