convert ae101 st to bt advice?
Postby vr4boy » Thu Mar 17, 2011 9:26 pm
i have a ae101 levin st 20v, its manual if that matters, my motor has seen better days and i was looking at fitting a bt 20v, ill be using the bt wiring and ecu also, im just wanting to no if this is just a straight forward swap and will ae111 bt engine loom plug in to ae101 st loom for dash etc..., any other advice would b awsome, thanks heaps.
ps, i tried to find if this has been covered before and ant find anything.
1995 ae101 levin st 20v
vr4boy
Postby AE82 FXGT » Thu Mar 17, 2011 10:05 pm
the best/cleanest/cheapest way:
sell your car and buy a bzr/blacktop whatever the hell you want
Sorry if thats not the answer you were looking for but its common sense.
AE82 FXGT
Postby MR2BOY23 » Thu Mar 17, 2011 10:14 pm
No i'm afraid not, the engine will drop right it but the engine managements are different, the black top needs to have the MAP sensor, IAT sensor and ECU from a blacktop car because the silvertop uses an AFM unit with it's ECU.
MR2BOY23
Postby MR2BOY23 » Thu Mar 17, 2011 10:16 pm
MR2BOY23
Postby soopachargen » Thu Mar 17, 2011 10:23 pm
The easiest way to do the wiring is to use the silvertop loom and modify it to suit, the IAT and MAP sensors wire into where the AFM was, and then you change the plugs for the ecu
When in doubt, down and out.
soopachargen
Postby Bling » Fri Mar 18, 2011 12:14 am
Doing it for fun / something to do: go nuts
Doing it to just get it going again: jam another silvertop in and save some $$$ and hassle.
Postby vr4boy » Sat Mar 19, 2011 12:58 am
just doing it for something to do as my bro in law has the bt loom and ecu sitting round collecting dust.
vr4boy
Postby rollaholic » Sat Mar 19, 2011 10:36 am
if you like the 101 shape i say go nuts.
just remember these things almost always cost more to do you than you originally imagine.
