2E Tempreture Gauge Problem
Postby Babz » Sun Mar 20, 2011 1:10 pm
Hey Guys. We just Completed a transplant of a 2e turbo into my mates ee100 corolla. Car Runs perfectly but now the Water Temp Gauge is shooting straight to hot as soon as the ignition is turned on. Used to work before. We have put in new sender unit and tried both the old 2e carb sensor and new turbo sensor but still the same. When it is unplugged the temp drops back down. Would anyone know what else i could try?
1982 Carina TA63 (in the making)
1986 Corona TT141 SR20DE (Rear Ended and For Sale)
1998 Audi A3 1.8T (wifes daily driver)
2011 Mitsubishi Triton (Work Ute)
Babz
Postby Stu- » Sun Mar 20, 2011 5:47 pm
You've got the oil sensor and water temp sensor wires around the wrong way.
Project Thread
Stu-
Postby Babz » Sun Mar 20, 2011 9:36 pm
Damn that was what i was going to try tomorrow. Lol. Thanks Stu. The only problem is i am still using the original Wiring loom from the old motor for the the gauges and ignition. So i am guessing that only one wire would be linked to the water temp gauge.
Babz
Postby Stu- » Mon Mar 21, 2011 8:07 am
Yes thats the right way to do it. The water temp and oil temp are both one wire so just swap them over and your away. Still ct12 turbo?
Project Thread
Stu-
Postby Babz » Mon Mar 21, 2011 7:51 pm
Yeap still CT12. Will upgrade when this blows. Running 0.8 bar at the mo. The wire that is connected to the Water Temp at the moment is what triggers the gauge , meaning when i pull the wire out of the Temp gauges drops off to dead cold. When i short the wire to ground the gauge shoots to the top (hot) . i will have another look tomorrow if i go over to my mates.
Babz
Postby Stu- » Tue Mar 22, 2011 7:31 am
Yes the dash guage sensor switches to earth ie lack of earth = cold, full earth = hot.
Project Thread
Stu-
Postby Babz » Tue Mar 22, 2011 9:09 pm
Didnt make it to my mates. But the wire that is connected to the Water Sensor is what triggers the Water Temp Gauge, meaning wouldnt that be the right wire is in the right sensor?
Babz
Postby Stu- » Wed Mar 23, 2011 7:14 am
Ah yep could be then. Right sensor? The one facing the firewall is for the fan just in case you have them around the wrong way?
Project Thread
Stu-
Postby Babz » Wed Mar 23, 2011 6:17 pm
Yeap Fan one is connected. Its the one facing the Left Chassis that i have connected the gauge wire to. The smallest sensor out of all of them.
Babz
Postby Stu- » Wed Mar 23, 2011 6:30 pm
Should be the one, only thing I can think of is that its not a linear sensor and is only on/off? Got a spare to try? Use the one off the original engine.
Project Thread
Stu-
Postby Babz » Thu Mar 24, 2011 6:59 am
Yeap used the one from the older motor and one from another 2E motor. Still no go. Looks like its going to be another long weekend. LOL.
Babz
Postby Stu- » Thu Mar 24, 2011 9:25 am
So if you earth the wire to the chassis for example the temp guage should go all the way to hot? This would indicate that the wiring/guage is fine. Got plenty of good earth straps the the engine?
Project Thread
Stu-
Postby Babz » Fri Mar 25, 2011 7:10 am
Yea plenty if earth. The guy at Taylors Auto Electrical reckons it could be the gauge as well. Apparently they have some kind of winding in them and if that burns out , it can not tell the difference between voltages and would read high or low and nothing in the middle. Worth a try getting another Cluster but i do not think it is going to work.
Babz
Postby gasman » Fri Mar 25, 2011 8:41 am
did it work before the conversion? i had a similar problem when i first swapped in a blacktop in place of a 4af, what it was was the ground from the gauge cluster not being connected to the ground wires going to the engine block.
"What can possibly go wrong?"
gasman
Postby Babz » Sat Mar 26, 2011 8:30 am
Yeap it did work. Means there should be loose wire some where that needs to be grounded. Thanks man, il try that out.
Babz
Postby Babz » Mon Mar 28, 2011 12:08 pm
Tried looking for that wire with no luck. Might have to pay and call in the professionals.
Babz
