BZG|Bling wrote:If there is one thing i've found, everyone is an expert on oil/filters and recommend different ones each time![]()
Not a big cost to go genuine filters. Not sure what i'm even running at the moment, I think its ryco or something. Have used Fram, Genuine, Repco etc.
Stu- wrote:BZG|Bling wrote:If there is one thing i've found, everyone is an expert on oil/filters and recommend different ones each time![]()
Agree. However cut a few different ones appart and you can see the difference in the amount of filtering material inside. Genuine are worth it in my opinion.
YeMs wrote:[
I have cut a few filters open in my time and FRAM are definately my next option. the ryco filters are pretty questionable imho.
evil_si wrote:YeMs wrote:[
Spotted a fram vs wix display fiters the other day, the wix had twice as much filter media inside than the fram
BZG Wagon wrote: 2) How much oil in the turbo is too much? When I pulled the intake pipe off the turbo there was maybe 1/4 - 1/2 a teaspoon sitting in there + a very thin layer of caked oil spread through most of the intake pipe. Also a little bit in what I think is the PCV breather. Can't say I'm overly worried about it - there didn't seem to be any play in the turbo. Is it something I should keep an eye on? Should I be a bit easier on the ol' turbo?
sergei wrote:Engine flush is kerosene.
It messes with seals, and loosens sludge (if engine is sludged) to a point where it blocks strainer.
