Mr Revhead wrote:I would imagine the best it would do is slow the melting process a bit.
I think water to air is the best for your application though.
Having helped scooped mud out of ducts in your car before, doing anything to not use radiators is a good idea!
I would think a large capacity water to air system would work best. You are pretty free on where you can put the water tank, you could stick it in the front for example. I guess weight is the next consideration.
If you ran it from the air heat exchanger to a radiator mounted out of the way, say with a fan behind the cockpit then into a large tank in the front, that may work. It's a matter of making sure the capacity isn't overwhelmed by the heat...
Possibly you could use aircon to blow on the water rad? that might have more of a positive effect than trying to cool a large volume of water with it.
Mr Revhead wrote:Mud. LOTS of mud. Then some more mud. And then force some more in there...
gasman wrote:Mr Revhead wrote:Mud. LOTS of mud. Then some more mud. And then force some more in there...
but wouldnt mud be a problem with the radiator for the water to air set up too?
Mr Revhead wrote:gasman wrote:Mr Revhead wrote:Mud. LOTS of mud. Then some more mud. And then force some more in there...
yes, but being used to cool the water for a water to air means you have a lot more freedom on where and how you place it. Whereas with an air to air you are quite limited.
Mr Revhead wrote:I think so too.
but some times by talking shit out loud you come up with something
