ae111 1998 bzr wiring schemeatics
Postby tim_blair » Sat May 14, 2011 10:54 am
does anyone know where i can find a set of wiring schematics for a 1998 bzr
in particular a schematic for the speedo cluster
girl: can I trust you?
me: you can trust anything :D
tim_blair
Postby touge_ae101 » Sat May 14, 2011 12:13 pm
There has got schematics in your local library but to be honest unless you spend all day looking schematics it probably wont make any sense. I know I didn't get much from it.
You can figure it out by using a 12v power feed to figure out each light etc. They are quite simply laid out behind the dash.
touge_ae101
Postby tim_blair » Sat May 14, 2011 12:21 pm
i do spend almost all day every day looking at wiring schematics....
yea i have made a new speedo cluster and wired it all up to the old one but i did it on an older model and the one on my car that i am replacing is slightly different
thtere is a chip that plugs on to the back behind the speedo and i dont know what it does plus the leds that i have used to replace the bulbs dont work
a schematic would just make things a little eaiser
tim_blair
