Blue HID Look Bulbs - Opinions Please :)
Postby Bling » Mon May 16, 2011 9:00 am
l3_vin wrote:Since then i do not support putting HIDs in older cars. Yeah that would explain my evo 6...beam pattern was normal and never glared etc.
So i'm guessing you have been followed and driven towards your evo at night to confirm this? I just would have thought a headlight reflector would be designed for one type of bulb, and wouldn't suit anything else. Age of car shouldn't matter. Guess it doesn't really matter since unless you replace the whole unit its illegal. New or old car.
Postby Brawler » Mon May 16, 2011 12:14 pm
Just leave them factory, i have no problems seeing at night
zing! Sig got nuked. Sorry bout that.
Brawler
Postby wde_bdy » Mon May 16, 2011 12:26 pm
Brawler wrote:Just leave them factory, i have no problems seeing at night
Actually, the best thing you can do is start with a wiring upgrade running relays straight off the battery. Will make a noticable difference to 90% of cars on the road, particularly older ones.
Callum
wde_bdy
Postby Jdawg » Mon May 16, 2011 1:52 pm
http://www.nzta.govt.nz/resources/virm- ... -v4a2.html
Reasons for rejection from the VIRM:
15. When switched on, a headlamp emits a light that is:
a) not substantially white or amber, or
b) different in colour or intensity from the other lamp in
a pair, or
c) not steady, or
d) not bright enough to illuminate the road ahead,
eg due to modification, deterioration or an incorrect
light source, or
e) too bright, eg due to the fitment of an HID
conversion kit (Note 8) or other incorrect light
source.
16. When the dipped-beam headlamps are switched on
Jdawg
Postby Mr.Phreak » Mon May 16, 2011 3:09 pm
wde_bdy wrote:Actually, the best thing you can do is start with a wiring upgrade running relays straight off the battery. Will make a noticable difference to 90% of cars on the road, particularly older ones.
Callum
Mmmmm, common sense, how I've missed you
Mr.Phreak
Postby sergei » Mon May 16, 2011 8:09 pm
Callum
This! I rewired the lights in my ST165, and they went up in brightness. Funny thing to see is people put 70W into lights where 55W was originally and it shines dimmer and redder because wiring can't handle it.
Postby Bling » Mon May 16, 2011 8:12 pm
Out of interest is it just a case of putting the relays right near the lights and wiring it inline from the factory feed and running the new feed from battery? I'm no sparky mmmk :)
Postby gt4dude » Mon May 16, 2011 8:53 pm
The best halogen replacement bulbs I've come across is the Philips (BlueVision is it?? I think 4000K) ones at Repco. They are expensive yes, they aren't all that white, but alot less yellow than stock and I think just a tad clearer vision. But - They don't blow out and leave shards through your housing like the chinese ones do, they run at stock wattage and are reliable for years.
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby wde_bdy » Mon May 16, 2011 11:03 pm
BZG|Bling wrote:Out of interest is it just a case of putting the relays right near the lights and wiring it inline from the factory feed and running the new feed from battery? I'm no sparky mmmk :)
My relays are mounted next to battery (front of engine bay) with power feed direct off battery, better earth for lights and triggered from standard headlight plug. Was an aftermarket kit that came in a car I bought.
Callum
wde_bdy
Postby l3_vin » Mon May 16, 2011 11:54 pm
Yes i have. Also kneeled down facing car it didnt glare. I am mates with the new owner.. he told me he put another HID kit on, due to the bulb blowing on old one. He then went and passed another cert.
l3_vin
Postby BlakJak » Tue May 17, 2011 9:18 pm
There's a FAQ article about vehicle lighting i'm surprised noone has pointed at yet
viewtopic.php?t=45506
BlakJak
Postby wde_bdy » Tue May 17, 2011 10:09 pm
You expect people to read the FAQ. 8O
Just to update thread, found one of my headlights had blown this morning so replaced 100/90W "white" bulbs with Narva Plus 50's (60/55W). Can actually see now, this is without any wiring upgrades in this car, definitely recommended.
Callum
wde_bdy
