AE82 FXGT factory alignment specs
Postby nile » Tue May 17, 2011 12:10 pm
Google has returned nothing other than this http://www.caesionline.com/wheelalign/s ... yota3.html
Which would be for a normal EE80, the FXGT would have a different spec I would imagine.
Could anyone shed some light on the spec or where I could find it?
nile
Postby B_giB » Tue May 17, 2011 1:35 pm
IIRC all E8* series corolla's had the same spec.
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby pc » Fri May 20, 2011 6:47 pm
Why would you need a factory spec?
Just set it to 0 toe and it'll be good enough.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby nile » Fri May 20, 2011 8:37 pm
Okay thanks for the replies. Just wondering what the factory toe specs were as a base point for my alignment. Will just start off with zero.
nile
Postby matt dunn » Fri May 20, 2011 9:57 pm
I had a feeling that zero toe makes cars wander all over the road at 100k??
Hardly any cars are zero's in the specs.
Postby holden_fan2005 » Sat May 21, 2011 1:35 am
+.5mm toe on each side, gotta be better than 0.
holden_fan2005
Postby pc » Sun May 22, 2011 11:16 pm
+ 0.5mm sounds pretty close to 0.
Could you get closer by trying?
red car
Manfield - 1:24s
pc
Postby THA SHZ » Sun May 22, 2011 11:26 pm
B_giB wrote:IIRC all E8* series corolla's had the same spec.
you are a liar sir :lol:
nz new is different to jap for starters as no power steering vs power steering created different castor and toe settings .
bad man brendan :)
il get you specs tomorrow 8)
THA SHZ
Postby matt dunn » Mon May 23, 2011 12:40 am
pc wrote:+ 0.5mm sounds pretty close to 0.
In alignment specs it miles away.
Postby B_giB » Mon May 23, 2011 8:54 am
bad man brendan :)
Hence I said IIRC.
Now come here so I can punish you...
B_giB
Postby pc » Mon May 23, 2011 7:55 pm
I've never done an alignment with a proper machine, but i've seen it done a few times. It might be an old car thing, but it looked like the error was around 0.5mm
Has anyone who actually does wheel alignments done the measurements then driven down the highway and then re-measured? I'd be interested to know the differences that were measured.
I figure that by the time you take into account the play in rack ends, tie rods, ball joints, bushes, wheel bearings, and wheel casting irregularities, that 0.5mm is about error.
red car
Manfield - 1:24s
pc
