Could a panhard rod bush be gone?
siren676 wrote:Could a panhard rod bush be gone?
Brawler wrote:drifting?
touge_ae101 wrote:siren676 wrote:Could a panhard rod bush be gone?
Sure it could be that would make sense but you are Probably more qualified to find that out by taking a look than us trying to guess from behind a screen..
Or it could of just been the wind (or a seagull farting) pushing your smaller than average car around! :p
Harlet wrote:More than likely one of the bushes. Easiest thing is to replace the lot with Nolathane ones if you still running factory bushes.
siren676 wrote:Autolign is probably the best place to get them from.
I think they have to be pushed out with a press.
Jacked the car up after work and all the bushes were alright when trying to move them with a pry bar. I think it must have been the loose gravel last night causing it to feel weird.
amdeman wrote:Harlet wrote:More than likely one of the bushes. Easiest thing is to replace the lot with Nolathane ones if you still running factory bushes.
Where's the place to find those, also what's involved in doing the job?
Cheers.
tsoob wrote:amdeman wrote:Harlet wrote:More than likely one of the bushes. Easiest thing is to replace the lot with Nolathane ones if you still running factory bushes.
Cheers.
get them from me
Will discount the price for toyspeed members
