Pukekohe or Hampton Downs
Postby MilfHunter » Thu May 26, 2011 10:44 am
I've heard the 3S & 5S motors have the same problem with the last corner at H/D.
A little extra oil should help
Entries for Sunday 29th have been extended, check the post under Auckland or the AMS website.
MilfHunter
Postby BZG Wagon » Thu May 26, 2011 12:33 pm
Thanks for all the info & advice everyone - really appreciate it.
After talking it over with my mate (also his first time) we've decided on Pukekohe for our 'first outing' (weather permitting).
He's just bought a Clubsport and wants to see what sort of speeds he can get out of it, and it sounds like Puke has a lot more areas to run off into should something go wrong ($30k car and he's had it for two weeks now so a little more aprehensive about Hampton). It also sounds like Puke will be quieter then Sunday's event at Hampton.
Once we get a bit more comfort out on the track we'll head to Hampton - it sounds awesome (bar engines drying up on the sweeper).
On a side note - shouldn't the oil warning come on if the pump stops sucking oil? (not sure where the sensor is or how it works).
BZG Wagon
Postby sergei » Thu May 26, 2011 3:10 pm
BZG Wagon wrote:On a side note - shouldn't the oil warning come on if the pump stops sucking oil? (not sure where the sensor is or how it works).
If the oil light is on, it is too late. I have been able to activate oil pressure switch by blowing into it, that's how low they are set.
Postby touge_ae101 » Thu May 26, 2011 3:13 pm
you must just be super practiced :P :P
touge_ae101
Postby Mr Ree » Thu May 26, 2011 3:26 pm
BZG Wagon wrote:Thanks for all the info & advice everyone - really appreciate it.
Without trying to sound too dramatic, I cant stress how important it is for you, and your friend, to slowly build up confidence, and speed, as the day progresses. Do not be tempted into going balls out down the back straight for the first few laps youre out there as you might find you dont have enough brakes left to stop you after you have gone from 180kph+ to 50kph a few times in succession.
There are no trophies on trackdays, just tears if things go wrong so just go out there and have fun, and dont be pressured into driving over your limits. :)
P.S If you find your engine its getting a bit warm, turn you heater to hot, with the fan on, this will help keep your coolant temps down a bit.
wak thud gush!
Mr Ree
Postby strx7 » Thu May 26, 2011 3:32 pm
MilfHunter wrote:I've heard the 3S & 5S motors have the same problem with the last corner at H/D.
Perhaps if they are 1st or 2nd gen motors. I know of a number of caldinas, and my own 5sgte corolla which did numerous laps there with no issues. the first couple of laps i took that corner a bit slowly and kept my eye on the oil pressure guage the whole way around to make sure it wasn't going to drop at all.
Postby touge_ae101 » Thu May 26, 2011 3:46 pm
last trackday i was at here at manfeild there was a late model merc (not sure what model but it was flash as $&#$%) he was driving it far too hard, lost brakes and went straight off the end of the straight into higgins at 200km/h. hit the wall so hard it moved the concrete barriers. he was very lucky not be injured, the crumple zone and crash testing on that car certainly work!
touge_ae101
Postby BZG Wagon » Thu May 26, 2011 4:03 pm
Mr Ree wrote:
BZG Wagon wrote:Once we get a bit more comfort out on the track we'll head to Hampton - it sounds awesome (bar engines drying up on the sweeper).
Thanks for the advice - I hear you man. I'm not the kind of guy that'll go out there and try to be a hero anyway (especially with my car being uninsured for the track). And that goes for any car I drive regardless of what it is or how fast it can go.
I've also had my GTT for just under 4 years now so I'm fairly comfortable with where it's limits are and what to expect from it, as well as my limits driving it (although I look forward to pushing it a little further on the track).
Getting use to being on a track and looking out for other drivers is main reason I plan to do a number of slow laps first and then build my speed up progressively.
I also like to think my GTT's fairly quick; so hopefully I won't be getting in the way of the 1600 n/a's and the like that that will be out there while I'm adjusting to a new enviroment.
BZG Wagon
Postby Mr Ree » Thu May 26, 2011 4:13 pm
touge_ae101 wrote:last trackday i was at here at manfeild there was a late model merc (not sure what model but it was flash as $&#$%) he was driving it far too hard, lost brakes and went straight off the end of the straight into higgins at 200km/h. hit the wall so hard it moved the concrete barriers. he was very lucky not be injured, the crumple zone and crash testing on that car certainly work!
I heard about that crash from a friend and have been expecting to see a clip uploaded to utube but as it was a few weeks ago now, Im guessing nobody got it on camera.
A prime example of how quickly things can go wrong, even in a modern 6 figure euro. Take care out there ya hear now kids, ;)
wak thud gush!
Mr Ree
Postby GTTpower » Thu May 26, 2011 4:59 pm
Went to Hamptons a while back to watch a couple of friends have a go around the track in their GTT's.
My advice, take it easy on the brakes, factory ones are useless on the track.
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Steam/Origin ID: nzEP85
GTTpower
Postby strx7 » Thu May 26, 2011 6:05 pm
GTTpower wrote:Went to Hamptons a while back to watch a couple of friends have a go around the track in their GTT's.
yeah, not really upto the task of stopping a station wagon on a track lap after lap
Postby Flannelman » Thu May 26, 2011 9:57 pm
Its abit hard to explaine what happens in an engine with oil as RPM risese. Yet the best I can think of is take an electric egg beater, some cooking oil and a large bowl. At low RPM, the oil being flicked up on the sides of the bowl are small and the drainback is fast enough to keep the puddle filled. As RPM rises, so does the amout of oil being flicked around, puddle gets smaller. Max RPM and start picking up the bowl and move it around to simulate cornering Gs and the puddle may dissapear. This for even a second happens in an engine and its metal on metal contact on berring surfaces leading to bearing failure. Having more oil in the puddle to start with puts this event further out of reach.
Flannelman
formerly known as Affroman
Postby BZG Wagon » Fri May 27, 2011 7:52 pm
Does anyone know where I can get a neck brace from tomorrow morning?
Been chatting with a good friend who is a paramedic - he has a few horror stories of helmets doing significant damage when used without an adequate brace.
BZG Wagon
Postby ch4ng » Fri May 27, 2011 8:56 pm
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby BZG Wagon » Sat May 28, 2011 6:39 pm
Wow - I had a great time at Pukekohe today.
I have so much more respect for my GTT - I had a good battle with an STi sedan and there was nothing between the two on the back straight (I led for two laps, then he led to for two laps). My GTT was dead even with my mates 5.7 litre 300kw clubsport until 150kph where he started to pull away. Great effort from a stock standard little 2l wagon I thought!
The only problem were the brakes - the factory pads just couldn't cope. Even when 'taking it easy' the brakes were getting bloody hot and I found 5 - 6 laps being about as much as I could get out of the car at any one time before they were cooked (that included a couple slow laps to get the car warm and the adjust to being on the track again).
I felt relaxed out on the track and everyone was real friendly when they found out we were first timers. Great day for only $90 (+ pads haha).
BZG Wagon
Postby siren676 » Sat May 28, 2011 7:03 pm
Good to hear you had fun and bought it back in one piece.
My brakes didnt cope either when i went there.
What sort of speeds were you getting on the back straight?
siren676
Postby strx7 » Sat May 28, 2011 8:04 pm
BZG Wagon wrote: My GTT was dead even with my mates 5.7 litre 300kw clubsport until 150kph where he started to pull away.
0-150ish is soley dependant on power to weight ratio, above 150kph its HP vs wind drag
Postby BZG Wagon » Sun May 29, 2011 11:17 am
siren676 wrote:Good to hear you had fun and bought it back in one piece.
I was hitting the limiter just approaching the slight bend leading up to the hair pin (so around 2/3rds the way down the straight). The clubsport was just getting a little over 200kph. How about your starlet?
If I go back again I might invest in some better pads. The wagon's a beast to throw around the track - some better suspension would go a long way too.
Yup - that's where all that extra torque helps. I recall my physics teacher saying 160kph is where aerodynamics start making a significant impact on a vehicle.
I can now see why people spend ridiculous amounts of money on their cars. I was walking away thinking I could easily drop some money into some decent brakes & shocks to make it go quicker around the track. It's an addictive buzz.
BZG Wagon
Postby siren676 » Sun May 29, 2011 12:18 pm
I was only just getting 160k's before braking for the hairpin.
siren676
Postby ch4ng » Sun May 29, 2011 6:51 pm
Did you end up getting a neck brace?
Good to hear that the jappas can keep up with the aussie muscle!
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
ch4ng
