20v clutches/flywheels
Postby Boost_4_Life » Sat Jun 18, 2011 3:58 pm
after some ideas on what people have used before. yes i have searched already...
silvertop coupled to t50 in my rally starlet. standard clutch and flywheel as far as i know. I have been having issues creeping in, in that after a stage the clutch is becoming hard to release and get the car off the mark when warm, ok when its cool again. I've just pulled the clutch out and to my completely untrained eye it all looks ok. Flywheel could probably do with a skim.
But while i've got it apart, what flywheel/clutch combos work well in this app? standard clutch has been good for 7 years of rallying, the engine is standard so its not like it has to deal with power. But i'm tempted on the flywheel front, as long as i dont sacrifice mid range pull...
what combo's have people used and what flywheels are available for silvertop peeps? would simply using a blacktop flywheel suffice?
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby Dell'Orto » Sat Jun 18, 2011 4:49 pm
Blacktop would be mint, or fork out for Toda etc. Probably wouldnt want to go too light in a rally car though. Clutch fluid isnt old and borked?
PS I hate you and your awesome shed/hoist
Postby Boost_4_Life » Sat Jun 18, 2011 5:38 pm
if you wanna bring your cars to hamilton you're welcome to use it brad! :lol: :lol:
fluid could be an issue, im only using castrol dot 4 stuff, maybe i should upgrade. its probably a season old, and possibly a bit grubby..
The rally beast
Boost_4_Life
Postby Bazda » Sat Jun 18, 2011 10:21 pm
Nice Fidanza alloy flywheel would suit you well
Along with a heavy duty pressure plate and puk solid center clutch.
Postby Boost_4_Life » Sun Jun 19, 2011 10:21 am
Bazda wrote:Nice Fidanza alloy flywheel would suit you well
I dont want anything too harsh, even tho its rally application. wouldn't this clutch be fairly hard for normal driving? what are the flywheels worth do you know?
The rally beast
Boost_4_Life
Postby Bazda » Sun Jun 19, 2011 10:58 am
Cheapest option is buy a new clutch.
Fidanza flywheels are about $500
Postby TRD_ZERO » Sun Jun 19, 2011 11:01 am
Solid center puck clutch would be crap to drive compared to the factory one u had been using. I wouldnt go to that extreme if u say the factory one suficed. Id go full face carbon kevlar, sprung center with heavier p plate. Will be nicer to drive. I picked up an aftermarket flywheel with trd clutch kit for 180. So there are bargains to be had. Otherwise a blacktop flywheel is the next best thing.
Previous:
TRD_ZERO
Postby QikStarlie » Sun Jun 19, 2011 12:13 pm
used blacktop flywheel and "heavy duty" rpm? clutch on my kp. nothing fancy but works well and had years of abuse, with some drags and drifting. on about 105rwkw .
QikStarlie
Postby Boost_4_Life » Sun Jun 19, 2011 12:42 pm
yea after doing more research i think blacktop flywheel is the simple option. do they bolt straight up to silvertop no problems?
The rally beast
Boost_4_Life
Postby QikStarlie » Sun Jun 19, 2011 12:50 pm
yeh same deal
QikStarlie
Postby sergei » Sun Jun 19, 2011 1:54 pm
Black top flywheel is exactly same thing as silvertop but with most of the outer ring where the clutch bolts on cut out.
Postby CXGPWR » Sun Jun 19, 2011 3:28 pm
I could hava a cheap good s/hand solution for you after stripping my car
I have surplus a 20v blacktop flywheel, a trd clutch pressure plate & trd clutch plate. If interested pm me
CXGPWR
Users browsing this forum: Bing [Bot], Google [Bot] and 33 guests
