GDII wrote:Cameras don't always get the same image as what you see with your eyes. Can you see the slight green between 6-7krpm and 40-60kph in the first photo you posted or is that just what the camera picked up?
gt4dude wrote:ive looked into this, the ones from the ledbulbs guy are of decent quality, not the best for light spread, but they seem to last a while before they blow.
a trick is sometimes the pins are bent the wrong way, if u correct them, they line up well and make a better seal inside the contact, this fixes flickering ones.
probably the best ones in nz, ive tried all the china crap, they all either blow or they are too dim
that superbrightleds site though, the americans in their forums seem to recommend them, but ive never bothered to import any to see
sergei wrote:gt4dude wrote:ive looked into this, the ones from the ledbulbs guy are of decent quality, not the best for light spread, but they seem to last a while before they blow.
LEDs blowing is big sign of something really wrong (they using wrong resistors or not using any current limiting and wiring whole bunch in series). A LED should last you decades if not centuries.
GDII wrote:After replacing the dead bulb with a 5W I think I will just buy 3 more 5W bulbs for the rest of the dash. I can't tell what the old bulbs are, all the say on them is Toshiba but they are quite dull and the 5W bulb makes the gauges and needles brighter more crisp.
Also on a side note the repco brand bulbs seem to go black on the inside after a sort while. Especially in the front park lights. When I install them they are clear. Is this normal or could there be something wrong?
sergei wrote:GDII wrote:After replacing the dead bulb with a 5W I think I will just buy 3 more 5W bulbs for the rest of the dash. I can't tell what the old bulbs are, all the say on them is Toshiba but they are quite dull and the 5W bulb makes the gauges and needles brighter more crisp.
It is a sign of really cheap bulb - the black is oxide deposits, which means there is oxygen in the gas inside of the bulb.
Users browsing this forum: No registered users and 36 guests
