same angle of mesh
Hmmm okay, weird!OllieS wrote:Nah, large type, as in your picture.
Does the na SW drive go into the top or the side of the gearbox?
RomanV wrote:Hmmm okay, weird!OllieS wrote:Nah, large type, as in your picture.
NA SW20 has it plug into the top, and it uses the small gear type.
Have got one of the electronic ones here somewhere.
Via Toyodiy, says that SW20 turbo uses 30 teeth in the box, 35 for the speedo drive gear.
I guess it's not too much of an issue for a transaxle, where it's unlikely that you'd change the final drive ratio.
Just found some pictures of MR2 turbo speedo drive... It does indeed run backwards to the rest. I wonder if many else do... Bah!
RomanV wrote:Toyota do this themselves, to make the speedo work correctly, as you could get a 30,31,32,33,34, or 35 tooth speedo just for a W5* gearbox.
sergei wrote:Isn't on transaxle the rotational speed of the speedo drive gear (the one that is driving speed sensor gear) is equal to rotational speed of wheels? Because it is located on the diff and rotating at same speed as crown and ultimately on straight line same speed as axles.
Malcolm wrote:wonder if the reason why my speedo works intermittently is because
Users browsing this forum: No registered users and 26 guests
