touge_ae101 wrote:for a standard engine - no
for an engine with cams and a tunable ECU - yes.
they are more of a tuning tool than a power upgrade thing. plus you can only use in to time in the exhaust cam as the intake is VVT.
20v4ageBT wrote:touge_ae101 wrote:for a standard engine - no
Cheers for that. I will just stick to getting ram tubes.
Burning Angel wrote:
Pretty much rams tubes are a waste without an tunable ecu too.
touge_ae101 wrote: decent set of extractors and a 2.25inch exhaust with a decent intake system
ch4ng wrote:I have a set of 33mm trumpets inside the factory plenum on my blacktop with atouge_ae101 wrote: decent set of extractors and a 2.25inch exhaust with a decent intake system
According to my personal butt-dyno I didn't notice too much of a loss in the low RPM range as its pretty gutless there anyways but it was much happier 5-8000RPM (over standard trumpets)
RedMist wrote:
And there goes the problem with butt dyno's.
You loose mid range and the top end feels stronger simply because the transition is bigger.
A 6kw gain at the highest HP RPM will probably loose three or four times that at useable RPM.
Helmholtz resonance is better used to broaden the useable torque curve so you place it at the lower end of your useable power band.
A very high percentage of cheap mods may give you a few KW peak but will make your car slower. In fact I can't think of one that works.
I guess the question is, do you want a dyno queen or a fast car.
20v4ageBT wrote: So what do you suggest?
Users browsing this forum: Bing [Bot] and 26 guests
