sergei wrote:Tried replacing sway bar bushes?
Heylin wrote:Hitting the bump stops perhaps. how much lower than stock are your springs ?
Do you know the spring rates of the new springs ?
Could be killing your OEM shocks.
MAC_HATER wrote:i had your problem in my AE111
i replaced all of the rear suspension bushes
never heard a knock from the rear ever again
Lloyd wrote:http://www.toyodiy.com/parts/p_J_1998_TOYOTA_LEVIN_AE111-ACFVF_4804.html
There is a joint in the end of each of those paired arms which you can feel play in the wheel when the car is up. The other arm is a rubber bush and usually has play, but not play that will cause noise. The joint in the hub usually doesn't give trouble either. The swaybar bushes wear out and knock, and the other joint at either end of the sway bar link can wear and give knocking noises also.
So start with seeing if the swaybar mount bushes have play, and check the swaybar link arms
Simon K wrote:My wagon was clunking like a mofo recently, replaced some bushes to no avail. Had it up on the hoist yet again with three people heaving on suspension components to find what was up.
Turns out it was the rear susp arm nuts, they were "less than tight". On that Toyo DIY page they are part numbers 48730G and 48730H
Mr Revhead wrote:Yep another for swaybar bushes and end links. If they are worn it will sound like you have bunch of marble sin the boot
whynot wrote:the rear sway arm links sounded like an empty trailer attached to my car when they wore out.
Users browsing this forum: No registered users and 36 guests
