Altezza RS200 Issues
Postby Demon » Sat Aug 20, 2011 7:46 pm
Hey guys
Im having a few issues with my partners RS200.
Changed the fuel filter in the tank today and now the fuel gauge has stopped working. Was working fine but stopped a few mins ago while driving. Fuel light came on then about 10 secs later the gauge was reading empty.
Any suggestions for a fix? Ill pull the pump out again tomorrow and see if its jammed or anything
Also its hesitating alot (was happening before the filter change) feels like it wants to pull but just wont. Thought the filter was blocked hence the change of fuel filter. It has gotten better but sometimes its just not keen to rev.
Ill try new plugs and cleaning out the AFM with some Contact Cleaner tomorrow but any suggestions on possible fixes would be great!
TIA
All your base are belong to us!
remember"Women wax their armpits and genitals,pul out their eyebrows,pluck their top lip and still wont take it in the arse "cos it HURTS!"
Demon
Postby AE82 FXGT » Sat Aug 20, 2011 8:23 pm
I don't know how the filter set up is on one of these but if it's part of the fuel pump assembly, and you had to pull it out, then you will probably find that the entire pump/filter assembly isn't lined up correctly in the tank and the float is jamming on part of the tank.
Make sure you put it in the same way you took it out.
AE82 FXGT
Postby Distrb » Sat Aug 20, 2011 8:37 pm
Fuel level float and arm will be fouling on the pipe it draws fuel through from the right hand tank. Takes a wee bit of fiddling around to get it sitting right.
Distrb
Regular Poster
Postby Demon » Sat Aug 20, 2011 8:56 pm
Cool thanks guys ill definatly check it out in the morning!
Demon
Postby KinLoud » Sat Aug 20, 2011 10:06 pm
hesitating?
Standard airflter or aftermarket?
Many 3sge altezza problems have been caused by aftermarket air filter causing problems - they seem to upset the air flow to the AFM
Good luck
ken
Postby Demon » Sat Aug 20, 2011 10:10 pm
Aftermarket. HKS intake pipe and filter. Made a big difference in power and responce. Has been on the car for a while and didnt cause any issues when it was installed
Demon
Postby Demon » Mon Aug 22, 2011 10:26 pm
Thanks for all your input, turns out the AFM was $&#$%. Adjusted the float in the tank and the fuel gauge reads properly and just installed a new AFM.
The altezza runs sooo much smoother now and pulls like a school boy!
Demon
