Understanding Toyota Transaxle codes
Postby xsspeed » Mon Aug 29, 2011 11:53 am
Does anyone have the good oil on understanding toyota transaxle codes.
More specifically the diff codes,
For example, a common one is C56-04A (open) vs C56-04C (lsd),
As far as I can tell, C relates to gearbox family, 56 relates to the different spec'd ratios or final drive? 04 relates to Diff pinions, and the A or C relates to diff type (Open vs type of LSD)
I have come across similar for the S series gearboxes,
S54-04A, S54-06A, and S54-06D.
So I assume the S54-04A, shares the same diff (size?) as the C56-04A.
S54-06A, has a larger diff (open) and S54-06D, has a larger (than 04A) and lsd diff.
What I am keen to find out is, what are the Diff ratios (between 04A, and 06A) and what specifically do the letters for the diff code signify? (ie is A - open, B - viscous LSD, C - Torsen LSD, D - Helical LSD ???)
Have found this from Mark/ae25:
http://www.club-k.co.nz/Forums/viewthread.php?tid=10452
And this chart in various forms (which is kind of what Mark has extended on above):
http://www.toysport.com/technical%20information/toyota%20differentials%20identifications.htm
Neither of which quite explain the last identifier - (ie 04A, 04C, 06A, 06D)
Postby Mr Revhead » Mon Aug 29, 2011 12:31 pm
Torsen and Helical are the same thing :wink:
I think I had it worked out back in the day but I've forgotten now I'm not dealing with it all the time :?
But the Letter is definitely telling you what type of diff it is. A is definitely open. And I'm pretty sure C is Helical/Torsen
Postby xsspeed » Mon Aug 29, 2011 12:33 pm
Cheers Rev, helical for D was a guess as there is S54 box in a front cut celica on trademe with a helical lsd with the 06D diff code.
Postby strx7 » Mon Aug 29, 2011 5:04 pm
the -04 -06 etc is the diff ratio in the box, never seen any chart as to what they equate to, i would assume each gearbox series would need its own chart.
Postby iOnic » Mon Aug 29, 2011 6:52 pm
Yeah varies from series to series and a lot of the possible combinations have no actual meaning other than being sequential numbers/letters referencing a list of possible options for that gearbox/final drive and may not necessarily mean the same thing when used in the same combination on another gearbox/final drive.
Postby ®usty » Mon Aug 29, 2011 8:48 pm
From the ST20# Celica series they had these, not too sure about MR2's
SS-I
SS-I 1994-1999
S54-04A LSD type: none
SS-II
SS-II (1994-1997)
S54-06A LSD type: none
SS-II Superstrut edition (1994-1995)
E56-04C LSD type: Viscious (I need more references to 100% confirm '04C', but does have viscious LSD)
SS-II BEAMS (1997-1999)
SS-III
SS-III Superstrut (1995-1997)
S54-06D LSD type: Helical
SS-III Superstrut BEAMS (1997-1999) same as 1995-1997
GT-Four
GT-Four 1994-1999
E154F- 08B
Centre differential: Viscous
Rear differential: Torsen
TRD
TRD Mechanical LSD I
To fit all ST202・203・206・207 (S54-###) 1994-1999 Superstrut or McPhearson strut. Factory equiped with a Helical lsd or no lsd.
41301-ST804
TRD Mechanical LSD II
To fit all ST202・203・206・207 (E56-04C/###) 1994-1995 Superstrut Factory equiped with a Viscious lsd only.
41301-ST000
Both S54-06A/D have the same Final Drive: 4.176:1 (via partno.'s)
The E56 has the Final Drive: 3.944:1
The S54-04A Final drive I dont know
®usty
Postby Santa'sBoostinSleigh » Tue Dec 20, 2011 8:52 am
Hilux Surf manual gearbox P151F AO2B - LSD or open?
I know the auto A34OF AO3A is open dif
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby strx7 » Tue Dec 20, 2011 9:29 am
Santa'sBoostinSleigh wrote:Hilux Surf manual gearbox P151F AO2B - LSD or open?
its R151F not P151F, same box i used in my JZN130 surf. A02B SHOULD be LSD, although not sure if 2 spider or 4 spider. to be a surf and with the late type codes it has to be a #ZN185 series.
Postby Santa'sBoostinSleigh » Tue Dec 20, 2011 9:37 am
cheers, sorry just going off what info I was given...
yep from KZN185
this box be any good with a 1UZ driving it?
Santa's Mega Sale
Postby strx7 » Tue Dec 20, 2011 9:39 am
yeah it'd be sweet.
that is the better box, the R150F has a shorter 5th gear than the 151 so you pull more rpm at 100kph
Postby Santa'sBoostinSleigh » Tue Dec 20, 2011 9:55 am
MINT, would just need a fan-dangled bellhousing then i spose...
Santa's Mega Sale
Postby strx7 » Tue Dec 20, 2011 10:07 am
lathe, part off, weld up and presto a bell housing.
Postby KinLoud » Tue Dec 20, 2011 10:14 am
Yeah - different fwd gearboxes have different final drive ratios....
From memory Corolla C series gearboxes are 4.3 final drive ratio
Starlet C series boxes have maybe a 3.9 ratio
Why?
The Starlet runs a smaller diameter tyre from factory so it has a ratio that will make the engine revs lower when cruising
Popular swap for starlet fans is to get the corolla final drive ratio so its easier to give the car a thrashing!
Ken
Postby strx7 » Tue Dec 20, 2011 11:45 am
KinLoud wrote:
Why?
Ken
hence Rav4 with its 4.9 diff into corolla = fun times indeed!!!!
Users browsing this forum: Google [Bot] and 20 guests
