Vehicle Check Engine No?
Postby Garreth27 » Wed Sep 21, 2011 10:46 am
I'm looking at buying a manual SXE10 Altezza and have found one I like and is a good chance I will be buying it. I've done a Vehicle report check done this morning and on the details under Engine No, its says RUSTED (WTF).
Report has the following:
Vehicle Type: Passenger Car/Van
Body Style: Saloon
Chassis No: SXE10-0027232
Engine No: RUSTED ????
Would that of just been someone taking the piss when they registered the car when imported?
Current Rides:
91 Gt Starlet - Forged 5efte Drag Toy
88 EP71 Turbo S Starlet Track Toy
99 SEX10 Altezza - Daily Driver
Garreth27
Postby Mr. Mainstream » Wed Sep 21, 2011 10:47 am
:lol:
Ive seen that before,
the number is unreadable due to rust but is there.
Pritty bad if on a modern altezz
Current:77 MK2 Ford Escort L 1.3L
75 MK2 Ford Escort L 2.1L
Had: 2X Early Subaru Leggys GT Wags, 1X Subaru RS, 1X 2004 Subaru B4, 2x BFMP Turbo Sedan Famil's, 2x BFMR Turbo Sedan Famil's, AE92 FX-GT, 97 Holden Calais 3.8L
Supercharged 12psi ,Escort, BZ-R
Various Others
RomanV wrote: Mr Mainstream: The king of the Pushrods?!
Mr. Mainstream
Postby Garreth27 » Wed Sep 21, 2011 11:09 am
Ah damit, was pretty keen on it to. Strange it got complied with Rust on it. Might have the vehicle checked out first before making a decision. Offer the owner even less now :lol:
Current Rides:
Garreth27
Postby ~SlideWays~ » Wed Sep 21, 2011 11:34 am
Would it not just be the engine number on the block which is unreadable? Hardly an issue really?
~SlideWays~
Postby Garreth27 » Wed Sep 21, 2011 12:09 pm
would'nt it be easier reading engin no off the firewall. Pretty sure not all engines display the no on the block
Current Rides:
Garreth27
Postby BZG Wagon » Wed Sep 21, 2011 12:13 pm
Can you get it changed / updated?
I.e. you might be able to use it to knock a few hundred $$'s off, then update it so it doesn't put off any potential buyers.
I'd also get a mechanical check done on it - get a truer report on the condition & history of the car. It sounds like laziness when it was imported (rather then taking 10 seconds to pull out a wire brush).
BZG Wagon
Postby rollaholic » Wed Sep 21, 2011 5:55 pm
the engine number on the firewall will only tell you the type, ie 3SGE etc.
the actual engine number is stamped onto the block, and will be something like 3S-1234567. and thats whats being referred to with the rusted business. which if its a cast iron block is not that surprising.
its also possible that its difficult to see and they took the easy way out.
rust on the engine is not of concern to the compliers, only chassis rust :)
Postby fuel » Wed Sep 21, 2011 6:30 pm
yeah I've come across a few which have been 'UNKNOWN' or 'UNREADABLE' or something similar. The early imports often had the chassis number put down as the engine number, which is the case of my 1980 car which came in and was registered in 1988.
LOUD NOISES!!!
fuel
Postby iOnic » Wed Sep 21, 2011 7:53 pm
Engine no is stamped on block as well as on the build plate to tie the car to the engine (legally required in some markets) Not really uncommon to have the number on the block unreadable so don't be put off by it. Half the time the number on the build plate doesn't match the engine in the car due to engine swaps etc. Most people don't take much notice of them. LTNZ will update the number if you're willing to jump through hoops.
Postby fuel » Wed Sep 21, 2011 7:58 pm
in the case of JDM market cars they don't have a record of the exact engine serial number on the chassis/build plate. I know Mitsubishi, Toyota, Nissan, Mazda and Subaru don't anyhow - just the engine type/code.
LOUD NOISES!!!
fuel
Postby Boosted_162 » Wed Sep 21, 2011 7:59 pm
Just looked at my GTR on carjam, Engine no: RB26-COVERED :lol:
Postby Garreth27 » Wed Sep 21, 2011 8:32 pm
Sweet, owner has taken it for a AA check which had good results. I know they aren't fully reliable still better than nothing. Also passed a vtnz wof this morning. Still going to try and get some $$$ off :lol:
Current Rides:
Garreth27
Postby rollaholic » Thu Sep 22, 2011 7:58 am
Boosted_162 wrote:Just looked at my GTR on carjam, Engine no: RB26-COVERED :lol:
yeah they are a pain to get to :P
iOnic wrote:Engine no is stamped on block as well as on the build plate to tie the car to the engine (legally required in some markets) Not really uncommon to have the number on the block unreadable so don't be put off by it. Half the time the number on the build plate doesn't match the engine in the car due to engine swaps etc. Most people don't take much notice of them. LTNZ will update the number if you're willing to jump through hoops.
dont recall ever seeing a complete engine number on a build plate myself
Postby matt dunn » Thu Sep 22, 2011 6:08 pm
rollaholic wrote:dont recall ever seeing a complete engine number on a build plate myself
i havent seen anything later model than early 80's with it either.
