strut shaft thickness
Postby RS13 » Mon Oct 03, 2011 8:51 pm
Just bought a strut for the missus's daily, however when I went to install I found that the shaft diameter is about 22mm, whereas the one I removed was 18mm.
Pretty sure the listing they used was quite specific to her model, it fits perfectly otherwise to the hub/swaybar/brake line etc. Is it worth going back and trying to hunt down an 18mm one or would the shaft/dampening difference be unnoticeable?
Cheers!
RS13
Postby sergei » Mon Oct 03, 2011 9:06 pm
The only draw back (if top hat bolts on properly) is that the stock bump stop might not fit without special treatment.
Postby RS13 » Mon Oct 03, 2011 9:14 pm
sergei wrote:The only draw back (if top hat bolts on properly) is that the stock bump stop might not fit without special treatment.
Yes, this is how I found out! Won't go on without a lot of persuasion. So you're saying I should be fine?
RS13
Postby sergei » Mon Oct 03, 2011 9:16 pm
I have almost twice thicker Bilstein inserts in my ST165, and it is fine ;).
Postby Lloyd » Mon Oct 03, 2011 9:29 pm
I think the point is that only one shock is being replaced so there will be a side to side difference
Postby sergei » Mon Oct 03, 2011 9:37 pm
Lloyd wrote:I think the point is that only one shock is being replaced so there will be a side to side difference
Oh yes, good point, didn't spot that. Always replace both if buying brand new. If you are bothering with s/h struts... well, good luck.
Postby RS13 » Mon Oct 03, 2011 9:51 pm
Given that replacing both would amount to a good portion of the cars' worth, I'm not too keen to replace the other one when its' working fine and not leaking, just after a direct replacement really. Sounds like it might be easier to try track down the same, looking at them side by side the body of the shock is considerably thicker and longer by an inch or so as well. Not s/h either, new part.
RS13
Postby sergei » Mon Oct 03, 2011 10:02 pm
Just beware that with one brand new shock and other well used, it will have tendency to pull to a side under hard braking.
Postby RS13 » Mon Oct 03, 2011 10:05 pm
I'd have assumed that for the front, but this is a rear shock? I can't imagine it being any worse than having a working one and a buggered leaking one.
RS13
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
