new_breed wrote:http://www.topgear.com/uk/photos/foreign-cars-2011-10-24?imageNo=7
Foreign cars we wish we'd got
Toyota Century
The only front-engined, rear-wheel-drive, V12 car Japan produces, the Century is a mighty lump of modern-retro-expensive brilliance. Looking like a monster Nissan Cedric, Toyota's home-market flagship gets a 276bhp, 5.0-litre V12 and has been produced in Japan since 1967, with its only major redesign in '97. The doors are fully electric, the suspension courtesy of air-ride, most are ordered with wool trim (quieter than leather) and have lace curtains in the rear instead of tints. Timewarptastic. Cost? Just £61,000. In Japan, at least.
The 1GZ-FE is a 5.0 L (4996 cc) V12 48-valve DOHC engine with variable valve timing (VVT-i). Bore is 81 mm and stroke is 80.8 mm, with a compression ratio of 10.5:1. Official output as per Japanese Manufacturers' Agreement is 206 kW (276 hp) at 5200 rpm although true power output is estimated to be around 230 kW (310 hp). Peak torque of 481 N·m (355 ft·lbf) is at 4000 rpm with over 400 N·m (300 ft·lbf) available from as little as 1200 rpm. The fuel injection system is controlled by two ECUs, one for each bank of cylinders. The engine is capable of running on a single bank of 6 cylinders should a malfunction occur.
wde_bdy wrote:There are a few of those engines floating around NZ going into various cars. I know of one early model Crown and also a Celica running twin turbo.
Callum
Callum
GTTpower wrote:Pretty sure 'fuel' used to have a century.
Mr Revhead wrote:wde_bdy wrote:There are a few of those engines floating around NZ going into various cars. I know of one early model Crown and also a Celica running twin turbo.
Callum
picsorban
Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey wrote:ok ok, i stand corrected.
Supra is not a sports car I've decided. Its a supercar
Mr Revhead wrote:Nah the NSX was a sports car
