RWD options for 2GR-FZE
Postby cogent » Wed Nov 16, 2011 5:54 pm
Long story short, we have a TRD Aurion 2GR-FZE and we want to run it in a north-south config for a race car build. What are our options in regard to this? I'm not familiar enough with the intricacys of mixing/matching boxes and engines to efficiently research it, although it looks like a hilux 1g bell housing will bolt up?
V160 would be great but I don't like our chances of finding one, how hard would it be to adapt a rb25det or fd3s gearbox? We're after a strong, reliable performance orientated box without going to a straight cut race box.
Any ideas?
cogent
Postby deaf_rattle » Wed Nov 16, 2011 6:09 pm
v160, you would need to chop off the "bellhousing" part as its all one part with the gearbox.
the 300zx 5speed is a very strong box, otherwise id go r154.
Postby cogent » Wed Nov 16, 2011 6:25 pm
I guess my question is more around what is the usual process for mating a gearbox to an engine, and with regards to the 2gr what bolt together options might we already have?
cogent
Postby nz_climber » Wed Nov 16, 2011 7:00 pm
Have a read here, its a 2gr going into a MR2, and uses a 3s bellhousing and box..
http://forums.toyspeed.org.nz/viewtopic.php?t=78710
working with that logic you should be able to use anything that came s series bellhousing, which include w series, also the altezza j160 (probably not the strongest, but I am sure there will be more options out there)
Otherwise you will be up for building a adapter plate or bellhousing..
nz_climber
Postby strx7 » Wed Nov 16, 2011 8:14 pm
w57 with a S series or C series bell housing or try a J160 Altezza box and see how it stands up, depending on what it is going into, it MAY handle some abuse.
Postby wde_bdy » Wed Nov 16, 2011 9:02 pm
Search www.Toymods.org.au forum, pretty sure there was at least one RWD version there.
Callum
wde_bdy
Postby KinLoud » Wed Nov 16, 2011 10:48 pm
Some late model (2002 onwards says wikipedia) Hilux have a 1GR-FE - the 4litre version of the 2grfe.
Go find bell and gearbox from one of these maybe
Ken
Postby Soiled » Wed Nov 16, 2011 11:15 pm
Altezza boxes are stronger than people give them credit for, if you keep oil changes up and don't be stupidly harsh on it.
Mines been on a turbocharged 3S at 200kw for about 50,000ks and 275kw for about 15,000ks with a couple track days in there and never given me problems.
But have known a couple not be so lucky, so could be worth giving it a go as they are relatively cheap (compared to r154) and if it's an easy fit.
Soiled
