kyb=trd? ??
kyb=trd? ??
Postby magweal » Mon Nov 21, 2011 10:38 pm
So I finally pulled the struts outta the carina(at210) which though were kyb's as I could see the stamp, when I got them out I decided 2 clean them a bit and low and behold there is trd stamped on them 2. My question is, is this right and could they fit a ae101( I need new shocks and I like the thought of trd)
magweal
Postby Dell'Orto » Mon Nov 21, 2011 11:36 pm
Yep, TRD and quite a few OEM shocks are made by KYB. Dunno if Carina ones would fit though
Postby strx7 » Tue Nov 22, 2011 6:38 am
the rear top hats should be a different bolt pattern, but if you change them to ae101 items you should be able to put them in your ae101 (i'm basing that on me putting st215 ones into my ae104)
Postby magweal » Tue Nov 22, 2011 7:14 pm
I'm hoping that's all that's different. Did u use the st215 springs?
magweal
Postby Bling » Tue Nov 22, 2011 9:17 pm
How old are the shocks? TRD or not, if they are well used it's kind of pointless putting in 2nd hand bits.
Postby magweal » Tue Nov 22, 2011 11:22 pm
I drove the car from wellywood and they seamed really good but I will get them checked out first
magweal
Users browsing this forum: Google [Bot] and 30 guests
