iamawesome wrote:I have a manifold with an external wastegate on it already that hasn't been used and the turbo from my gt4 has the wastegate welded up, might just get the flange changed and get the turbo redone to use the shit I already have. Guessing A twin scroll means it has the two exhaust ports on it? Then yes it is. The standard turbo keeps hitting boost cut so pretty keen to ditch it when I get the car back
iamawesome wrote: The standard turbo keeps hitting boost cut so pretty keen to ditch it when I get the car back
Phothog wrote:iamawesome wrote:I have a manifold with an external wastegate on it already that hasn't been used and the turbo from my gt4 has the wastegate welded up, might just get the flange changed and get the turbo redone to use the shit I already have. Guessing A twin scroll means it has the two exhaust ports on it? Then yes it is. The standard turbo keeps hitting boost cut so pretty keen to ditch it when I get the car back
Dont use the CT26 off the GT4, Smaller compressor wheel than the supra, ceramic turbine wheel & smaller turbine housing...
in basic words.. its a downgrade.
a Garrett TA3410 is a good budget turbo, ($1210) but is T3 Flanged
or a off the shelf T04B Komats turbo ($1380) Split pulse T4 Tlanged
Or upgrade your CT26, bolts on no stuffing around.
Chris.
