Torsen oil
Torsen oil
Postby tiny2009 » Thu Nov 24, 2011 11:38 am
Getting torsen installed tonight but need some oil. How much oil is needed and what viscosity?
Normal grandad oil is fine? Anyone have particular recommendations for brands?
Diff is from a Turbo manual jzx100 or 90 and going in the 110.
tiny2009
Postby edwagon » Thu Nov 24, 2011 12:26 pm
I always ran Valvoline Duragear 75w/90 in mine
Its a semi synthetic GL5 rated oil - good quality without the baby's blood pricetag.
A jzz30/jza80 diff takes ~2L, Altezza 0.9, jzx are somewhere in between
edwagon
Postby 2jayzgte » Thu Nov 24, 2011 7:29 pm
Last diff oil change I did in my Supra with the Torsen I used Redline Synthetic 75W 90NS.
2jayzgte
Postby tiny2009 » Thu Nov 24, 2011 9:23 pm
Cheers guys, its installed now and what a difference it makes.
tiny2009
Postby EssDub » Sun Nov 27, 2011 9:28 am
11s outside your house yet?
1992 SW20 MR2 GT-S Turbo
Previous Rides: Mazda 323, Toyota Levin BZ-G, 1992 SW20 MR2, 1994 Gen3 SW20 MR2 T-Bar
EssDub
Postby tiny2009 » Sun Nov 27, 2011 4:46 pm
Not outside my place.
Anyway, I don't do those sorts of things in the 'camry'
tiny2009
Postby BlakeNZ » Sun Nov 27, 2011 8:19 pm
make sure you use a normal gear oil in the torsen diffs, not an "LSD oil". this is important. i use 85/90 grade, and change every 20000km or so if driven hard.
BlakeNZ
