Quint wrote:Compression rings?
Stuff them into your honed bore (with a touch'o'oil) find out what the end gap clearance is supposed to be (0.03-0.07mm for a 1g, iirc) stick a feeler gauge in there and go 'aw yea'.
Don't see why the gap would change from factory spec?
DFECTED wrote:Think you have your decimal point in the wrong place. .012"-.016" or 0.3-0.4mm is about right
Quint wrote:DFECTED wrote:vert, make sure you check the ring sizes, found that toyota changed the top compression ring thickness by a few thou between gens on the 1g, so possibility of the same thing happening on the 4a.
