Well I seem to be having all sorts of strange issues with this car the latest a stalling issue it developed last week.
ok so it's an early 1jz ge in a ex 7m powered cressida. It was working fine but it has now started stalling only after going above 80ks for a few minutes. I pull up at an intersection and it either idles really low say 2/300 rpm then stalls or just dies before I even come to a stop. Once I restart then its fine until I go above 80ks again.
So far I have checked the idle control valve. ignition timing, earthing and ecu for fault codes. next on the list is tps for correct adjustment and operation.
Anything else I am missing or should check?
