Who makes a deeper 30mm socket to undo Hub/CV nuts?
Postby xsspeed » Mon Dec 19, 2011 11:50 am
As per title, (I think they are 30mm?) looking for someone who makes a deeper socket so I can get some hub nuts off - using a 1/2" breaker bar.
Some seem to come off fine but other the threaded spindle sticks out too far.
Or do I need to go to 3/4" gear?
Postby 2LTR Rona » Mon Dec 19, 2011 12:02 pm
Power built
1/2” Dr Axle Nut Sockets/Loose
Built to exceed ANSI Specifications
For easy removal of front wheel drive axle shaft nuts
Impact Grade 6 point socket
Extra deep to fit various axle lengths
Black chrome vanadium
648470
648469 30mm
648470 32mm
648471 34mm
648472 36mm
http://www.powerbuilttools.co.nz/powerbuiltsockets.htm
2002 Altezza, 1974 KE25
2LTR Rona
Postby sergei » Mon Dec 19, 2011 12:03 pm
I use kingtony deep 30mm 1/2" socket without any problem for that task.
Postby xsspeed » Mon Dec 19, 2011 12:05 pm
Sweet cheers!
Postby touge_ae101 » Mon Dec 19, 2011 1:22 pm
got mine from toolshed i think. its just a powerbuilt socket must be relatively common. pretty pricey though IIRC mine was ~$50. invaluable when dismantling cars though so prob worth it.
touge_ae101
Postby Bling » Mon Dec 19, 2011 1:37 pm
Put your welder to good use and make something :wink: chop a crappy old standard one in half and add extension legs or something haha.
I got this set a couple years back, suits most, but nothing that quite fits 30mm.
http://www.trademe.co.nz/building-renov ... 760905.htm
Postby Malcolm » Mon Dec 19, 2011 2:34 pm
I extended a 30 and 32mm socket as BZG|Bling suggests, they do the job fine :)
Postby RunningRich » Mon Dec 19, 2011 3:15 pm
Koken also do one. Only gets used every couple of years but is vital when needed.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby DeeCee » Mon Dec 19, 2011 5:31 pm
super cheap calibre range - $11 or similiar pricing. I ended up buying the 30 and 32mm.
GT Four Adovansu
DeeCee
Postby jaypines » Mon Dec 19, 2011 7:53 pm
note that late model toyotas (year 2000 above) need a 12 point 30mm socket.
jaypines
Postby DeeCee » Mon Dec 19, 2011 8:45 pm
just counted the calibre socket = 12 point
GT Four Adovansu
DeeCee
Postby Lloyd » Mon Dec 19, 2011 8:56 pm
Most tool manufacturers will make them. Cheap ones will break eventually. Buy impact ones, regardless of if you're using them on air tools or not
Postby DeeCee » Mon Dec 19, 2011 9:03 pm
of course cheap ones will break, but for that odd job, the calibre is fine. Otherwise I use my Ampro or impact sockets, but at the time, I needed a cheap fix :)
GT Four Adovansu
DeeCee
