iOnic wrote:That's pretty shocking. My Mondog gets between 6 and 8L/100km and weighs as much as a small planet.
I do too, with a manual 4WD g-spec one. Just figured it was heavier than the 2WD 3S-GE Curren I had, and sucked it up. Darn family wanting a four door wagonpaulngui wrote:Hi, I just filled up my car and worked out that I got 10.9 L/100km from my last tank. My drives are 90% suburban with just a couple of motorway trips; and I try to drive economically, never revving it higher than ~2400rpm.
This seems extremely high for an NA Caldina with the not-very-powerful 3S-FE motor; just wondering if anyone else with this engine gets this bad economy.
BZG Wagon wrote:I try to check my tyres monthly (maybe a little obsessive). A couple times a year is on the other end of that scale so you should definately keep an eye on it more frequently. You can also look at less grippy tyres if you've got something fancy on it.
An annual service is a poor effort too - every six months or 10,000kms at least. More often if you drive it in traffic regularly.
To run diagnostics just locate the check connector, which should be close to the drivers door, by the little compartment thingy where your knees are. Bridge TC & CG and turn on the ignition. Count the engine flashes then google them to see if there are any issues.
samlloyd wrote:Dont try and keep the revs under a certain amount. Its all about how hard you press on the accelerator.
