Jonno2002 wrote:does it make any difference if you pump the pedal a few times before starting it ? carbed cars tend to need a few pumps
whynot wrote:if i remember those ga carbied motors have some sort of heated bi metallic strip on the carb which is for temperature compensation/idle on start up. it is adjustable from memory but that was a good while back so i may be mistaken.
iOnic wrote:Ignition system alright?
RS13 wrote:Would timing have much effect on the cranking? It runs perfectly otherwise which rules that out possibly?
Leon wrote:if you try to crash start it, is it still a bitch to start (which would suggest carb) or does it fire straight away and run ok (which would suggest electrical), or does it fire up straight away but want to stall (which still suggests carb to me).
allencr wrote:RS13 wrote:Would timing have much effect on the cranking? It runs perfectly otherwise which rules that out possibly?
Yes, zero effect.
What's the compression?
Running any aftermarket accessories or anything off of a convenient place like the coil?
Tried different methods like 1 or 3 pumps, holding the throttle down a little, a lot or not at all?
Checked the auto choke plate for completely closed when cold & completely open when warm, with enough spring tension/pre-load in those positions to be unaffected from the air flow?
Spark nice fat & blue or a thin yellow zap? Close up the gap if it's yellow & try'er out.
rollaholic wrote:isint a DS actually single point injection? which is known to give issues. as i recall whatever goes bang inside can be repaired, but its not particularly cheap.
if the plug gaps were wrong its prob cos they have worn away and need replacing.
