Mr Revhead wrote:I wouldn't think so. I think it would depend on where the hole is in relation to the fire ring. I assume that's where the gasket was leaking?
Possibly fill it in with some metal repair stuff to give more support to the gasket.
Grrrrrrr! wrote:Doesn't look great, I'd be looking at skimming the block to get a good surface for the gasket to seal against. Depends on the condition of the rest of it tho, and whether you would be happy with a slight compression increase.
crispy'86 wrote:How many spare blocks have you got Sergei?I had this exact dilemma when i did the race motor in my Fx, well my low budget build std race motor. Had ongoing head gasket troubles a.k.a took 3 times to start it in morning and then eventually picked up in the revs, went alright but got sick of it. Pulled engine out after other troubles and wasn't happy with the block surface, very similar to yours. Easiest would be get 2nd hand imported engine??
sergei wrote:problem #4: Bottom end is a bit noisy (can't hear it without knock sensor headphones).
isn't that what he said in the last post about 3sgte's on here somewheresergei wrote:
MAGN1T!!!!
Grotty wrote:isn't that what he said in the last post about 3sgte's on here somewheresergei wrote:
MAGN1T!!!!
Akane wrote:I don't get it, you're earning shitloads of money, why don't you just get a nice Gen 3 and be done with the headache?
