Alex B wrote:Mr Revhead wrote:Warming it up by idling is mean to the car
Even with AC down here in the middle of winter you're a fool if you don't warm up the car so you can see out. $&#$% the car.
Insert S13 pics here?
Mr Revhead wrote:Defrost with warm water, no problem!
Mr Revhead wrote:Warm enough to heat the glass so it will not refrost. That way it also won't fog on the inside as it's not cold.
Alex B wrote:Mr Revhead wrote:Warm enough to heat the glass so it will not refrost. That way it also won't fog on the inside as it's not cold.
You have not lived in Dunedin have you?
The most fun was the MR2's demister lines would freeze up and well there is a lack of warmth under the bonnet to unfreeze them...
