Just interested to see what it is for.
this is the part.
Here is where it is located
Grrrrrrr! wrote:Vacuum switching valve, switches vacuum signal from plenum to..... somewhere.. trace the hoses..
blindnz wrote:Sweet, makes sense now. It has two hoses in one from the throttle body and one thats tee'd. (nothing to the charcoal canister)
So yeah would make sense its an idle up solenoid. How does this work, so when there is a change in vac it pulls the solenoid closed which send the signal through to the ecu to idle up?
anyhow from the sounds of things its a bit messed up anyway to be clicking/buzzing when ignition is off. So I'll try pick-a-part a replacement.
