New ct20b record. 365rwhp @ 22psi. Gen2 3sgte
Postby Rookie » Thu Jan 26, 2012 12:51 pm
The only accurate way to measure power is to know the weight of the vehicle and run it down the quarter, then calculate from trap speed.
Rookie
Postby sergei » Thu Jan 26, 2012 12:59 pm
Rookie wrote:The only accurate way to measure power is to know the weight of the vehicle and run it down the quarter, then calculate from trap speed.
too many variables. (Atmospheric pressure, humidity, air temperature, traction, driver, wind, etc.).
Postby Lith » Thu Jan 26, 2012 1:28 pm
Who cares how much power something supposedly has, dyno is a tuning tool for measuring what effects various power making related changes have - at the end of the day those specific numbers mean nothing compared to what happens when you put the combo to a real test, whether it be on the track or on the strip :)
2007 Mazdaspeed Axela
Lith
Postby Al » Thu Jan 26, 2012 5:24 pm
Not really.
Say your GT4 usually traps 100mph in the 1/4. If you just roll off the line cleanly, chances are you will still run 100mph rather than dropping the clutch at 6000rpm.
If you can get the car off the line cleanly, and not miss any gear shifts, you will be quite consistent with your trap speeds. An amazing driver isn't going to get faster MPH than an ok driver.
Trap speed = horsepower.
It goes without saying that not so favourable humidity and air temps will have an effect on the trap speed, because you aren't making the hp, so you don't pull the numbers.
Al
Postby iOnic » Thu Jan 26, 2012 5:48 pm
Lith wrote:Who cares :)
Postby Grrrrrrr! » Thu Jan 26, 2012 6:15 pm
So big wings = -20HP and a tail wind = +20HP in your world?
Grrrrrrr!
Postby headshotnz » Thu Jan 26, 2012 7:04 pm
Hmm, I would have thought thats what an engine dyno's for.. but whatever
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby strx7 » Thu Jan 26, 2012 7:53 pm
so what happens if say you trap at say 100mph in a GT4 with a 3.9:1 RC box in it, ya then fit a 4.9:1 rav 4 box, go to the strip again and trap at 115mph because you can accelerate faster, you are still making the same power at the motor.......
Postby RedMist » Thu Jan 26, 2012 8:19 pm
And this is why my dyno plots are used with tire diameters and gear ratios to calculate torque at the wheels. I then modify the ratios to maximise wheel torque all the way to maximum speed.
But even that isn't a full measure of engine performance. Throttle response, torque curve, rev through, etc.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Al » Thu Jan 26, 2012 8:34 pm
No you would go slower if anything. The taller gears would keep you in each gear longer, allowing you to get more speed per gear, and potentially not have to shift into 4th gear before the end of the 1/4.
Al
Postby strx7 » Thu Jan 26, 2012 9:57 pm
i only have one responce to that reply :lol: :lol: :lol: :lol: :lol: :lol: :lol:
if that is what you honestly think, you have NO idea.
Postby kim0663 » Thu Jan 26, 2012 10:20 pm
This whole debate and conception of a dyno is redundant and WRONG imo.
It's a relative measurement tool, not absolute...
Mr2 GT-S
330ci M
kim0663
Postby Lith » Fri Jan 27, 2012 10:04 am
strx7 wrote:No you would go slower if anything. The taller gears would keep you in each gear longer, allowing you to get more speed per gear, and potentially not have to shift into 4th gear before the end of the 1/4.
if that is what you honestly think, you have NO idea.[/quote]
Actually I'm leaning towards the contrary on that one, especially if you actually think you'll gain anywhere near 15mph on the strip by doing that!
I actually feel that trap speeds on drag strips are a more consistant way of getting an indication of relative power than dynos, different dynos can read up around +/- 7% for a given car. I found at least using my Skyline that my trap speeds ranged from 110mph-113mph depending on a good or bad day weather wise, tyres, how good I drove so long as there wasn't a complete epic fail resulting in excessive "coasting". I changed tyre size, tyre pressure, tyre type, and rims on a variety of those... everything from 255x40x17 Nankang NS2s running 32psi to 26x11.5x16 MT ET Streets running 12psi.
Using my own car as an example - my dyno results deviated by as much as 10% with no changes between dynos, while my trapspeeds deviated by about 3%.
Lith
Postby strx7 » Fri Jan 27, 2012 11:57 am
that diff ratio gives 25% more applied torque at the wheels and it accelates like you have 25% more torque. perhaps it wont gain 15mph but it would sure gain, and it sure as hell wouldn't go slower. working on the "it would go slower" logic, why do cars even have a 5 speed box? might as well just have a 2 speed box with a low and a high as some people think it would accelerate just as fast.........
what diff ratio is your skyline? a 4.1 or there abouts? put a 5.1:1 in the back there and tell me you aint going to get down the strip faster. you'll probably get closer to running out of rev range in 5th gear.....
Postby saft » Fri Jan 27, 2012 12:08 pm
strx7 wrote:i only have one responce to that reply :lol: :lol: :lol: :lol: :lol: :lol: :lol:
now this is an interesting one, because its a great candidate for calculation and comparison.
it depends on on the power/torque curve and gear ratios amoung other things.
i remember back in the day you had something like "torque is cheap, power costs money" in your sig on sdu? i still dont agree with that :lol:
027 516 0556
I f**king love cheeseburgers.
saft
Postby Lith » Fri Jan 27, 2012 1:36 pm
strx7 wrote:why do cars even have a 5 speed box? might as well just have a 2 speed box with a low and a high as some people think it would accelerate just as fast.........
Funny you should say that! Ever heard of a Powerglide?? Here's one of the worlds fastest Supras ... it runs a 2speed gearbox:
http://www.youtube.com/watch?v=rBSU-vQ1pAQ
Should teach them a thing or two? ;)
Lith
Postby saft » Fri Jan 27, 2012 3:42 pm
just for fun i tested out some numbers in Cartest
http://www.cartestsoftware.com/index.php
Its not the be all and end all but it lets you make simple comparisons.
1990 Celica All Trac was already in the database, so i used that.
4.29:1 final drive: 15.43 @ 87.57
5.29:1 final drive: 15.47 @ 86.84
027 516 0556
saft
Postby Grrrrrrr! » Fri Jan 27, 2012 5:48 pm
Bit of a difference between something that has enough power to smoke the tyres at 100mph and the other 99% of cars out there. :)
Grrrrrrr!
Postby Akane » Fri Jan 27, 2012 6:19 pm
Sums up this thread.
Postby Al » Fri Jan 27, 2012 6:38 pm
You are just jelly Akane :P
Al
