C52 ... C60 ... lsd
C52 ... C60 ... lsd
Postby flying_wedge » Fri Jan 27, 2012 7:51 am
Might be an obvious answer to this question, but it pays to check :)
I have a C52 with an lsd, and a C60 open diff. Being the same gearbox code, could I swap the lsd from the C52 to the C60?
What are tolerances on diffs with power? Current C52 dealing with ~160 engine hp, will be facing ~210 hp in C60.
flying_wedge
Postby thegreatestben » Fri Jan 27, 2012 9:24 pm
Had a c52 open diff in the 7agte adub. She'll be right ;)
thegreatestben
Postby CXGPWR » Sat Jan 28, 2012 1:35 am
Had a C56 in my fxgt, had 230whp 4agte, held up mint and was only a shitty torsen lsd but that took a hammering
CXGPWR's 1985 Toyota Trueno Racecar Spec
Build Thread
Discussion
CXGPWR
Postby crispy'86 » Sat Jan 28, 2012 8:44 am
C60 or 160 6 speed out of ae111 levin/trueno??
I thought (and don't quote me) the lsd unit would work but the crown wheel is narrower on the 6 speeds?? It has been a while since i stripped the gearbox in a customers 6 speed bzr trueno that popped the gearbox.
crispy'86
Postby GTTpower » Sat Jan 28, 2012 9:13 am
C60 is out of ZZE123 Corolla's, much stronger unit. Can you actually swap the bellhousing to accept an A engine?
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Steam/Origin ID: nzEP85
GTTpower
Postby flying_wedge » Sat Jan 28, 2012 12:57 pm
Its a c60 6 speed, not c160. For a 2zz.
Have lsd for a c52, and I would be keen to know if this would fit the c60 box. Many years between them I know, but same gearbox code ...
flying_wedge
Postby crispy'86 » Sat Jan 28, 2012 12:58 pm
I've wondered this too as our corolla fielder has the 1zzfe and C52 5 speed so........ would it just be a straight bolt up to the block or do you have to strip the box to fit the A bolt pattern
crispy'86
Users browsing this forum: No registered users and 26 guests
