i just got a filter sock from the local radiator place.
undo top hose, slip over radiator end, push the tail into the radiator, put hose back on.
looks a bit like a finger off a cotton glove, caught a lot of crap in my cooling system.
Quint wrote:pressure is force over area :/
1I1 wrote:Is it something that you only leave on for a short time?
Otherwise it could stop the flow of water/break due to all the crap collecting in it?
Mr Revhead wrote:I can sell you a proper coolant filter if you want.
But if I were you I'd be looking to overhaul the system properly
saft wrote:i just got a filter sock from the local radiator place.
gt4dude wrote:I'm gonna tip the radiator upside down and hang it up, block off the hot port and jam the garden hose in the cold port and the radiator cap should help pressure remove the crap in there, then...
