no_8wire wrote:Keeping in mind that this is a daily run around.. not keen on running meth/water injection... I would rather just play with intercooler/turbo/ fuelling than upgrade the fuelling system...
Loses the point of been a cheap run around then doesnt it?
no_8wire wrote:Mr Ree wrote:You can buy extremely cheap misters from the gardening section of bummings
bummings?
Not sure if Im too keen on visiting there tbh...
Is that Bunnings gay cousin or something?
sergei wrote:
Simples solution is a throttle microswitch (same type as used on basic NOS).
was reading through all these complicated solutions, seems like the obvious option to me & Considerably easier that silicon chips etc
in my race car i just re-plumbed the washer bottle to a sprayer and just sprayed on the straights,worked a treat
Mr Revhead wrote:Could run into problems if you leave puddles. So nozzle choice is important.
cat007 wrote:Mr Revhead wrote:Could run into problems if you leave puddles. So nozzle choice is important.
Yeah that's what I was thinking
I'm 90% sure they are not allowed, or at least you're not allowed to use them, at Meremere. Not sure about circuit tracks though....?
iOnic wrote:I doubt IC water spray systems are banned anywhere. Lots of factory cars use them. You are just as likely to have a leak in windscreen washers, headlight washers, cooling system etc
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 19 guests
